check panel quit working
  • e-dirtym52
    • Aug 2012
    • 338
    I just recently pulled my cluster to wire in my vss and after reading up a little more I found out late model vss just goes through the harness. But when I put my cluster back in my check panel quit working. I made sure everything was back where it was but why would this happen.
    And after going back and going through my wires I connected my vss pin 14 to 14. Yet my mpg still doesn't work.
    Any opinions? I checked with a volt meter and the pins are getting power
    If you're not going to do it right, please don't take it out on your car!
    • 34835
    MPG isn't based on VSS input to the DME. the MPG signal is pin 8 (white/black). ALl the DME does is send a conditioned injector signal to the cluster, the SI board calculates everything else.
    I think you must have bumped something loose when messing with your cluster. the check panel not working isn't directly related to the cluster or DME.
    • e-dirtym52
      • Aug 2012
      • 338
      Hmm. Well the blinking "check" on the cluster isn't going off anymore either so maybe I'll just find a new cluster and try it out. Keep the other for a backup. So the black white wire on the engine side needs to go to pin 8 for mpg? I'll go back through wiring tonight
        • 34835
        maybe the bulb is broken, burned out, or got disconnected somehow.
          • 34835
          it's white/black. black is for RPM.
          • e-dirtym52
            • Aug 2012
            • 338
            OK when I get home I'll look back at everything and get let you know what I find out
