I am doing my second M50 swap to my 1984 325e in a month or so here and I have most of this sorted from my old M50NV swap, but I want to run a Getrag 240 this time and need to know what fw/clutch and Pilot bearing to run versus the G260 swap I did in my last 24V car.
I have heard that I can use the M50 dual mass in the G240 and I have heard i must use M42 or M20 single mass in it. which is true?
with the M50TU, and getrag 240:
can I run the M50 TU flywheel, clutch, pressure plate and TOB?
can I run the G250 pilot bearing?
I use E36 325i 5 speed DS with backward E30 carrier bearing or do I use a stock E30 5 speed G260 drive shaft?
the shift carrier I have heard use G240 hardware or use G260 hardware, which is true?
does the G240 use the same pilot as the G250 or the G260?
