found contradicting info, anyone clear up a G240 question?
  • E30stan
    • 658
    #46
    Originally posted by 2.5-12
    if you drill the output flange out to M12 diameter, you can just run an E36 325i guibo though from what I gather.
    thats what i did, guibo fits fine
    • 2.5-12
      • Jan 2010
      • 1814
      #47
      cool, thanks!
      1991 E30 M3 Brilliant/black - S54B32/5M
      1990 E30 318iT RHD Lagunagrun/tan - S52B32Turbo/5M
      2011 E82 1M VO/blk/6M
      1991 E31 850i red/grey/6M
      1997 F355 spider red/tan/6M
      • spyde25
        • 157
        #48
        I just used 10mm id 12mm od sleeves and it fits perfectly. Ordered from mcmaster carr
        my 88 325i sedan
        • nokincy
          • Feb 2012
          • 302
          #49
          Got a link?
          Was thinking about using these. http://www.mcmaster.com/#standard-sl...arings/=lw9p2z
          • spyde25
            • 157
            #50
            Originally posted by nokincy
            Got a link?
            6679k14
            McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
            my 88 325i sedan
            • 2.5-12
              • Jan 2010
              • 1814
              #51
              g240 has a 13mm spline tip, getrag 250 has a 15mm. pilot bearing change still required.
              is the g260 even larger?
              guess I'm going with a 250 after all, such a headache.
              • moteren_werke
                • Mar 2013
                • 16
                #52
                I did not read the whole thread but...
                I used:
                M50 NV
                Getrag 240 ( with 240 trans brace )
                Shift support arm from a E30 320i M20
                Shift rod from a E30 320i M20
                E36 325 manual D shaft ( 3 holes front, 4 back ) I did not reverse my CSB/ Ran my M42 guibo
                all e30/z3/4 shifters work fine
                Clutch, all m20 stuff, single mass flywheel, early eta starter, PILOT BEARING m20 and M20 TO bearing
                • 2.5-12
                  • Jan 2010
                  • 1814
                  #53
                  that is helpful, actually.
                  I assume you still ran an E30 CSB, but not reversed?
                  from what I gather the 240 and 260 have a 12mm i.d. pilot bearing
                  the 250 and ZF have a 15mm i.d. pilot bearing.
                  • 2.5-12
                    • Jan 2010
                    • 1814
                    #54
                    g250 and zf310/320 are the only two trannies with the big input shaft.
                    g240 and 260 have the small one.
                    • E30stan
                      • 658
                      #55
                      stock s52 dmfw/clutch/pp does not fit in the getrag240 housing, looks like ill be running the zf after all!
                      • moatilliatta
                        • 6157
                        #56
                        So, Im looking to put a getreg 240 (m42 e30) trans into my Ti which has the zf 250. Looks it will work minus the pilot bearing size and output flange to guibo bolt size. Transmisison lengths the same? Im using m20 single mass flywheels / starter so should have no issue there.
                        @Zakspeed_US
                        • 2.5-12
                          • Jan 2010
                          • 1814
                          #57
                          I think that is correct. the only thing that appears different is the location of the shifter arm connection on the top of the trans and you will need the G240's slave cylinder. M10 bolts as well on the guibo.
