What is the best Aux Fan?
  • aeryk7
    • Oct 2005
    • 616
    #31
    Go get yourself 2 bottle of redlines water wetter
    253rwhp
    My Vids(OLD)
    http://www.youtube.com/user/aeryk7#p/a/u/0/hS4ZAzSdUdY
    http://www.youtube.com/user/aeryk7#p/u/2/C-0hnV2k_xU
    • matt
      • 3731
      #32
      Why? It won't lower his overall coolant temp.
      The best aux fan is to have a main fan that's engine driven.
      • Brew
        • 3060
        #33
        FWIW, my 318is came with a curved-blade aux fan. I got the euro, non-ac mounts and have it on a switch. No problems so far-- I've sat in stop-and-go traffic for over 1.5 hours in 95 degree temps.
        '91 318is
        • matt
          • 3731
          #34
          Do you have a real temperature gauge, or do you rely on the stock POS (which is dead center from 170-230 degrees?)
          • FredK
            • 14761
            #35
            u get the memo on fans from the bf.c e36 m3 board? :mrgreen:
            • matt
              • 3731
              #36
              I'd bet it's just as true for e30s. I'll probably have a real gauge installed shortly, I'll let you know. I am not sure if there's room for the e36 or e30 stock clutch fan with the M50 swap, but I intend to find out. If there are clearance issues, I've heard (same source as the gauge info...) that the e36 318i clutch fan is thinner from front to mounting point, so I may try to use that.
              • jrez
                • Oct 2005
                • 71
                #37
                Im currently looking to replace my electric fan experiment(2 fwd early '90's mazda ones)as they are not able to keep up with the A/C on/hot ambeint temp.
                My situation is Im not running the engine driven fan.
                So then, what do you guys recommend in terms of a standalone electric fan(s) with the option to retain the 2 speeds?
                Cheers
                John
                At the race track.
                • Sean
                  • 5793
                  #38
                  Dan, you might be able to answer this.
                  For the fan switch - it just controls the ground then, going into the fan? Say I wanted to wire it to run on two temps - would I need two relays - one for the low speed and one for the high? Then run a resister in the 12v source on the low speed?
                  Here's what I picked up on Saturday:
                  30 AMP Auto Relay
                  Bunch of 18 guage wire
                  Simple switch (which I'll be using to activate the relay when it's not running itself)
                  LED that I wanted to wire in to turn on when I have the fan switched on or when it's running by itself
                  IM trying to figure out the best way to wire in my fan. I only want the switch to work when the car is on, otherwise the fan will run using the temp switch. Anyone got some hints?
                  Started my own thread here to get more views and poassibly just start up a new one. http://www.r3vlimited.com/board/showthread.php?t=73039
                  - Sean Hayes
                  • e30_kid89
                    • Apr 2006
                    • 489
                    #39
                    ha, funny this thread comes up when i start planning to run one with my swap. my plan was to first relocate the aux. fan into the other side of the rad and somehow mount it, then re-wire it so that it only working @ highspeed and that i can turn on the fan manually from the confort of the driver's seat. highspeed only becuz im going to be running a m42 rad with my m50.
                    i think this is very simple way to have an electrical fan... my a/c is dead and i dont plan to use/have it so might as well make use of the fan that just sits there.
                    Devon
                    • e30_kid89
                      • Apr 2006
                      • 489
                      #40
                      maybe you can wire your switch into an acc. lead so it will only come on when the car is on?
                      • Sean
                        • 5793
                        #41
                        That's the idea.
                        I jsut thought of this. I'm sure you all know the door gong - maybe I cna connect it the 12v wire for that - since the gong only operates after the car is on anyway! (or the key is in the ignition.)
                        - Sean Hayes
                        • e30_kid89
                          • Apr 2006
                          • 489
                          #42
                          That's the idea.
                          what would be even more certain is if you connect it to your radio's acc lead....yes i know its a long way from the fan in the engine bay but you will get your fan turning on the the key in the ignition..thats what im planning on doing:)
                          Devon
                          • equate975
                            • Jun 2004
                            • 3382
                            #43
                            Devon
                            I did that, only problem I found is if you turn the radio off the fans turn off too. So dont tap the white wire ;)
                            Rollin' with a Geistkuchen
                            • japspecvr6
                              • Apr 2005
                              • 602
                              #44
                              hmmm....anybody got a pic of a spal fan.....with A/C
                              M52 |S52 Cams|E36 Rack Swap|GC Coilover Kit |. . . . . . . . . More To Come
                              • jrez
                                • Oct 2005
                                • 71
                                #45
                                I used the e36 2 speed switch on mine. I reversed the power feed, feeding power through the ground, and connecting to the respective low/high speed existing e3o aux fan circuits.
                                Cheers'
                                John
                                At the race track.
