What is the best Aux Fan?
  • Drew325is
    • Oct 2004
    • 520
    Originally posted by 325Projectz
    Its really going to depend on your setup. Is the fan going to be a pusher or puller?
    You might have trouble fitting it if its a puller, if it fits at all.
    And are you going to have A/C? If not, you'll most likey be alright. I couldn't tell you if you do have A/C.
    Yeah I'll definitely be running the A/C. Sounds like I'll just have to wait and see what will fit once I get the motor in.
    Thanks anyway!
    • ptownTSI
      • Jun 2005
      • 1265
      can the fans be wired up with a low/high relay?
      i want to manually control the fan on low/high (like when parked to help it cool off) and i want the fan to come on automatically on low at 195 (sound about right?) and on high at 215.
      those $50 fans on ebay are a nice find, much better than doing a $55 sachs cluth fan replacement, can they fit on an A/C car though??
      http://cgi.ebay.com/ebaymotors/ws/eB...ADME:B:EF:US:1
      http://cgi.ebay.com/ebaymotors/ws/eB...tem=8032265565
      • DanGillan
        • Mar 2004
        • 4061
        i went with a single speed 13" SPAL pusher fan. mounted right to the front of the radiator. (no A/C)
        wired it up to come on with the low temp radiator switch even when the key is off, so if you park your car hot, the fan stays on until the low temp switch shuts off.
        I also used the AC switch as a manual switch to turn it on for any reason if the temp switch hasnt kicked it on yet.
        the ultimate set up IMHO. super quiet, PLENTY of air, perfect wiring set up. i'd reccomend this to everyone.
        Dan
        • ptownTSI
          • Jun 2005
          • 1265
          thanks dan. does it have a high and a low? no sense to be drawing full amperage if you arent going over 215 or so.
          • DanGillan
            • Mar 2004
            • 4061
            nope, single speed. hooked up to come on at low temp
            Dan
            • hugh jass
              • 2220
              Dan, could you give a little more detail of exactly how you wired the fan? Did you use the stock E30 fan switch that mounts on the stock E30 electric fan? I'm trying to figure out how I'm going to do the cooling on my car and want to get a better idea of what you have in my head. Thanks.
              ______________________
              ex-Chief Operating Officer
              Blunt Tech Industries
              West Coast and Pacific Rim
              • bmws50b30
                • Aug 2005
                • 1151
                why don't you ask your friend steve or superdooper bobbycooper, he's good with electricals
                1991 330is
                • hugh jass
                  • 2220
                  steve is now an ex-friend. i should ask bobby though. thanks lil friend.
                  • DanGillan
                    • Mar 2004
                    • 4061
                    i used the coolant temp switch that's on the side of the radiator, break out the diagram and find the low temp wire and the ground, basically you just use this switch to connect the ground side of the fan circuit. i have a wiring diagram drawn out by hand, but it took me a while and i dont feel like giving my information away :)
                    if you read what i wrote on the last page and break out the wiring diagram you should have no problems wiring this thing up. as long as you know how to wire relays and dont forget an in line fuse.
                    Dan
                    • equate975
                      • Jun 2004
                      • 3382
                      Heres a crappy pic of my setup, I couldnt find a better one of the fans
                      I used two 10" Hayden fans that I got at a local store
                      http://www.haydenauto.com/electricfans.htm
                      IIRC the CFM is just a tad lower than the SPAL ones.
                      I quickly found two 10's is huge overkill. I have them both on a manual switch right now, its sounds like my car is an airplane about to take off when I flip them on. I am usually running at 170-180 tops degrees in F.
                      I think the best plan for me anyways, is to have one start with the car, and have the other kick on at around 200F. I also picked up a fan-switcher-oner-thing-based-on-a-temp that I will hook up. You can set it to any temp you want then have a fan or fans kick on.
                      Rollin' with a Geistkuchen
                        • 34844
                        anyone try using the lower temp fan switch (80/88c) and the stock AC fan? supposedly it flows a ton of air.. that's my plan for now.
                        • hugh jass
                          • 2220
                          Do you have a part# for the lower temp fan switch?
                          Anyone know what CFM the stock fan moves? its a big honker, and the electric motor is pretty large as well.
                          • bmws50b30
                            • Aug 2005
                            • 1151
                            hey carl, any progress pics of your swap?
                            1991 330is
                            • hugh jass
                              • 2220
                              lol, i just posted a thread after you wrote this
                              • Mike B.
                                • Jan 2006
                                • 987
                                Can you just wire in a larger SPAL fan using the existing aux fan wiring and just add a larger fuse/relay if necessary?
