M50 rev limit confusion
  • Biddy627
    • Mar 2012
    • 41
    Been searching everywhere and can't find the answer. Does anybody know if the AUTOMATIC NON VANOS m50 ecu's had a rev liniter or not. Want to know before I finish my swap whether I need to buy a limiter or find a new ecu
  • Varinn
    • 780
    I'm pretty sure all fuel injected BMW's come with a rev limiter, I mean I could be wrong, but to my understanding all of them should have one.
    1990 332i, 4 door
    2008 KTM 990 Superduke
    2018 Golf R, 6spd manual (Pending delivery)
    2017 Mazda CX-5 GT
    2007 Z4M Coupe - Sold to very nice people
    • atmobenzin
      • 151
      The truth. ^^^
      Except if someone has put in a chip which raises/removes it.
        • 34844
        buy a limiter?
        all of them have it - you can't "remove" the rev limit, but you could raise it way higher than the engine is capable of.. if you can program the DME, that is.
        • Biddy627
          • Mar 2012
          • 41
          Thanks for clearing up the confusion, was worried cause my old 2.7 stroker was running an auto ecu and didn't have a rev limiter
            • 34844
            yes it did.
            • GunMetalGrey
              • Dec 2010
              • 1499
              Possibly not, a friend had a 325e with a dinan (I think, may be wrong on that) chip that had no limiter. Needless to say his engine didn't like it very much when he was accelerating hard and hit a ice patch...
              But if it's a stock ECU you have a limiter, no doubt.
              • SwiftE30
                • Jun 2010
                • 998
                Nando rocked it on this one. 99% of the time an ecu without an aftermarket chip/tune will have a rev limiter.
                1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IP
                  • 34844
                  It always has a limiter. It may be raised higher than you ever reved it, but it still has one. You cant turn it "off".
                  Also, automatic e30s dont have different DMEs - and they have limiters too.
                  • 328ijunkie
                    • May 2007
                    • 3961
                    ^That. My auto M20 auto will slam into the limiter all day long
                    Check Us out on Facebook
                    Full Product Line Tuning
