o2 sensor placement s52/obd2
  • ClausE30
    • Sep 2011
    • 981
    Hey guys, I just installed my first motor! (s52) and I was wondering where the o2 sensors should be placed? motor is obd2 setup. Looks like accessing the o2 sensor ports on headers will be next to impossible with motor in :/
    Thanks!
    91 Alpinweiss2 318is OBD2 S52
  • e30austin
    • 15382
    Using stock OBD2 manifolds or headers? You might be able to fit one in your headers and have a bung welded in your down pipe for an 02 sensor, if you can't get the other.
    I was able to fit one 02 sensor in my Supersprint header, but it was damn tight.
      • 34844
      you can put them on the sides after the collectors. you just don't want them with the sensor end pointing up or at the bottom of the pipe.
      • R3Z3N
        • Jan 2011
        • 3056
        Curious, why not pointed up or down? I have an ODBI S52 and the O2 sensor is pointed straight up after the collector.
          • 34844
          it can point down it just doesn't normally fit that way.
          pointed up is bad because at the bottom of the tube water can collect and damage the sensor.
