EDIT: Latest as of 07/01/13
Issue: Injectors are not getting grounded, CPS does not read RPMS on diagnostic tool. .
I checked for continuity to the Crank position sensor and its good.
Car cranks hard.
Park neutral safety switched properly jumped (hence cranking)
Checked continuity to DME from injectors.
I can manually ground Injectors an they click
I am getting fuel all the way to the injectors
I have spark
BMW Diagnostic tool is not reading RPMS (yet im getting spark??)
Tried 3 different 402 red label, 1 402 silber label.
Swapped 2 harnesses, one from a Auto 525i 92, second from a 92 525i manual
tried 3 differnet Crank position sensors, 1 brand new from BMW directly, NONE read a mothereffin signal. All check out perfect OHMS
History:
Like an idiot I first of all bought the motor in pieces in boxes, it took me months to figure everything out, source the last bit of missing hoses, clips, sensors, brackets etc etc...it was a nightmare.
On top of that, my E30 hasn't ran in close to 2 years because I once again like an idiot, did everything at once (respray, manual swap, dash swap, shaved engine bay) then left the project untouched for 1 year or so. Ive spent weeks now trying to really focus in on the project and get everything tied up correctly, and I am pretty sure majority of things are exactly where they belong.
Any Ideas what the hell is going on and why the CPS is not reading? It cant be that everything is bad.
Harness adapter has been checked, double and triple checked by 5 different sources.
-89 325i
-Getrag 260 swap
-E34 Wiring Harness
-92 M50NV
Can something on the car be causing the engine not to fire? Can something under the dash (i did dash swap) not have been re-connected properly? Can something have been fried keeping engine from running?
Car cranks hard.
I have spark
History:
-89 325i
-Getrag 260 swap
-E34 Wiring Harness
-92 M50NV
