Strangest Wiring Harness Ever M50 swap HELP
  • haggardfab
    • Sep 2011
    • 283
    Make sure you have the ground on the front of the motor coming from the fuel rail area.. Pretty sure thats the injector ground
    IG: haggardfab
    • berlow94
      • Jan 2013
      • 1063
      M50 motors use any Bosch/Siemens injector...
      The 24# injectors we got higher impedance then the ECU would fire, we swapped them out with injectors of the proper impedance and it started right up.
      The best one-stop shopping for German car parts and lifestyle: http://www.gutenparts.com/
      • osborne519
        • Jun 2013
        • 17
        every thing on mine is factory all is correctly hooked up in a correct way but the injectors will not fire ive been over the whole thing multiple times injectors have voltage, coils have spark, injectors wont fire
        • berlow94
          • Jan 2013
          • 1063
          Have you tried swapping out the injectors?
            • 34847
            DME is powered up? is it getting an RPM signal? does the fuel pump run?
            • CaffeinatedSoul
              • Jan 2016
              • 170
              I really hate digging up old threads but does anyone know what the wire he is holding goes to? It seems to be unheard of, as this is the only thing I can find even showing it exists. Its a brown wire with an orange strip on it coming from the wire harness. I need to know what to do with this wire.
                • 34847
                brown with an orange stripe will be a ground wire. There's a grounding post on the passenger side strut tower, put it there.
                Just make sure it's not really a red wire that has faded brown, or all the magic smoke will leak out of your harness. :p
                • CaffeinatedSoul
                  • Jan 2016
                  • 170
                  Is there any proof anywhere on this or a way to check outside of stripping the wiring harness?
                    • 34847
                    99.999999% sure its a ground. I've touched many harnesses and spent hundreds of hours studying BMW wiring diagrams - if that isn't a ground, I'd be shocked.
                    You can always test it with a multimeter, using a known ground pin of course (brown or brown with an orange stripe)
                    • CaffeinatedSoul
                      • Jan 2016
                      • 170
                      That's what i thought just haven't got a chance to test it yet. I'll do that when I get back to it. Thanks again
                      • scarecrow
                        • Apr 2013
                        • 45
                        Is the red wire circled in orange the engine harness main power supply?
                        • CaffeinatedSoul
                          • Jan 2016
                          • 170
                          Yes it is
