m50b30 !
  • b3albakii
    • 107
    m50b30 !
    hello guys can i have some infos about m50b30 swap ?
    1986 325E
    1989 320i
  • DesertBMW
    • Aug 2011
    • 1043
    It is same as M50B25 swap.
    • b3albakii
      • 107
      i have this swap in my car but i want to make my b25 , b30
      1986 325E
      1989 320i
      • DesertBMW
        • Aug 2011
        • 1043
        Take parts out of this block and install in your B25 block. That's it, all parts fit.
        • RoadHazard
          • Sep 2007
          • 163
          What's the gain over the b25?
          90 E30 S50B30
          http://www.fquick.com/roadhazard/
          • Roysneon
            • 4505
            .5l
            Originally posted by mbonanni
            I am a pursit now.
            • Poorboyz
              • May 2012
              • 2117
              Approx. +50 HP at the crank
              Sent from my Galaxy Nexus using Tapatalk 2
              Rebuilding since 07/06/2016
              Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
              Poorboyz Feedback Thread
              • Roysneon
                • 4505
                That seems like a lot. I'm assuming that's with the addition of cams, headers and a performance s50 chip?
                I am a pursit now.
                • RoadHazard
                  • Sep 2007
                  • 163
                  Originally posted by Roysneon
                  .5l
                  90 E30 S50B30
                  • Poorboyz
                    • May 2012
                    • 2117
                    2.5L - 189hp
                    3.0L - 240hp
                    I believe those are stock numbers. I'm sure someone else with more knowledge will chime in, I'm a noob. I believe the M50b30 was the US M3 engine?
                    • Roysneon
                      • 4505
                      2.5L - 189hp
                      3.0L - 240hp
                      No, the US M3 engine in 1995 was the S50b30. It had different cams and engine tuning but was still very much based on the M50tub25. An M50 with the same displacement but 'weaker' cams and a more mild factory tune won't make S50 numbers.
                      I am a pursit now.
                      • DREWHALL
                        • Feb 2006
                        • 1207
                        Correct. It is a punched out M50 with more cam, and I'm sure a little tuneage. Head casting is the same I believe.
                        • b3albakii
                          • 107
                          should i upgrade injectors ?
                          how about your advice guys should i go for it ?
                          1986 325E
                          1989 320i
                          • DesertBMW
                            • Aug 2011
                            • 1043
                            Don't go for it.
                            • digger
                              • Nov 2005
                              • 6213
                              should gain peak torque in proportion to the change in engine size. lowend will be alot better yo, but without breathing mods the gains in peak hp might not be as dramatic as lower in the rpms
