Bouncing idle while rolling
  • sludge1300
    • Jan 2011
    • 62
    My idle has been bouncing up and down when my car is rolling forward. Seems a bit strange as it won't do it when it's stopped. Otherwise the engine seems to be running well.
    So far I've checked for vacuum leaks visually and sprayed lots of starting fluid everywhere. Haven't found any leaks. I also cleaned the MAF.
    Engine is an OBD1 M52.
    Any ideas?
    Thanks
    -Chris
  • berlow94
    • Jan 2013
    • 1063
    Auto or manual?
    The best one-stop shopping for German car parts and lifestyle: http://www.gutenparts.com/
    • sludge1300
      • Jan 2011
      • 62
      Originally posted by berlow94
      Auto or manual?
      manual.
      -Chris
      • Fusion
        • Nov 2009
        • 3659
        Happens to me too. No idea why. I pop into neutral and coast to a red light and the revs bounce a couple times from 500-800 or so.
        • butters
          • 1202
          some light reading... http://forums.bimmerforums.com/forum...oaching-lights
          I've adjusted my technique to minimize the effect, basically you can't simply drop into neutral from elevated rpm. let us know if you find the fix.
          • berlow94
            • Jan 2013
            • 1063
            Chip? Lightweight flywheel?
            • sludge1300
              • Jan 2011
              • 62
              Great link. Thanks. Plenty of things in there I can try.
              TRM chip. Stock flywheel.
              Auto or manual?
              Oops, I forgot actually that my car's a manual swap. Of course I'm running that one red DME that deletes EWS or whatever. Can't remember the deal for some reason.
              -Chris
              • justin_l_
                • Jun 2007
                • 1079
                I know it's a differen car, but I had to adjust my Coast fc setting. Maybe it is an issue with the tune? I don't know if they can adjust the coasting fuel cut on our ecu's or not.
                • ClausE30
                  • Sep 2011
                  • 981
                  This happens to me too, sometimes it stalls while rolling to a stop in neutral
                  91 Alpinweiss2 318is OBD2 S52
                  • maclogos
                    • Jun 2013
                    • 120
                    I always thought it was due to the fact that you are in motion the airflow can cause this. My m50 does this too and i have had many mechanics tell me its normal when the car is rolling in neutral. Maybe they just say that since they dont wanna fix it lol. Other than that my car runs well. Idle is perfect at a full stop.
                      • 34839
                      it's the idle control. it's not catching the engine as the RPMs drop too fast - could be settings, could be the ICV being gummed up, etc. vac leaks will make it worse, so will a light flywheel.
                      • 328ijunkie
                        • May 2007
                        • 3961
                        ^+1 not normal for the most part.
                        Check Us out on Facebook
                        Full Product Line Tuning
                        • sludge1300
                          • Jan 2011
                          • 62
                          Swapped the DME: no change. Cleaned the ICV: decreased the amplitude of the idle bounce, but didn't fix it.
                          Unfortunately I don't have another chip that I could try
                          -Chris
                          • mitchlevy7
                            • Aug 2011
                            • 672
                            this happened when I replaced my ICV. had to disconnect the battery and let the ecu reset and relearn the ICV and it worked fine afterwards.
                            www.cp-e.com
                            1989 Zinno 325i m52 turbo coupe
                            2015 Ford Fiesta ST, Daily Driver.
                            • bzboardz
                              • 1096
                              this happened to me, ended up being one of the 3 wires to the TPS was corroded and not making contact. good luck!
