93 525i 5speed vs 2/95 325i 5speed
  • Jean
    • 18228
    Are these two EXACTLY the same, or could they be different?
    Trans in my 525i has as shitty 2nd gear from previous owner, I basically have to "granny shift it" or skip 2nd and up-shift to 3rd when possible or it grinds.
    There is a 2/95 325i with a 5speed, but I would like to know if they are exactly the same or not?
    Thanks!
  • 328ijunkie
    • May 2007
    • 3961
    Some early usually NV e34 525s had zf boxes
    Check Us out on Facebook
    Full Product Line Tuning
    • DesertBMW
      • Aug 2011
      • 1042
      Yes up to 7/1992 525 has ZF. 8/1992 has Getrag 250
      if its 1993 then 525 will have the same Getrag 250 as all of E36 325i have. I think the output flange is different on 5 series but you can swap that.
      • Jean
        • 18228
        Since mine is 93 vanos car sounds like it should have a Getrag
        Thanks
        • Dj Buttchug
          • Jun 2010
          • 7688
          sorry to thread jack but can you use either trans?
          Turbo M42 Build Thread :Here
          Ig:ryno_pzk
          I like the tuna here.
          Originally posted by lambo
          • DesertBMW
            • Aug 2011
            • 1042
            Yes you can, but you got to use the corresponding driveshaft and shifter.
