So I had issues in the past with losing power but I thought it was because of a somewhat mangled wiring harness. So after swapping harnesses and all that it only throws an evap code because I don't have my charcoal canister hooked up. But it still pretty much falls into a fail safe mode at full throttle. At like half throttle it will almost kick when getting up into rpms. I'm thinkong maybe vanos but I want too sure since it seems to idle fine and all that. So what do you guys think it could be?
m52 power loss at full throttle
If you're not going to do it right, please don't take it out on your car!Tags: None -
It also runs super rich. Backfires like crazy when I let off the gas if that says anythingIf you're not going to do it right, please don't take it out on your car! -
Any insight would help guysIf you're not going to do it right, please don't take it out on your car!Comment
Doesn't sound like Vanos to me. Usually that causes a problem below 5k. It will hesitate and surge during power.Derek-Comment
Well like half throttle it surges when it climbs up in rpms. And anything past half throttle it falls flat on its face. But I do have an extra vanos I got from a friend. Is there any way to tell if it's good or not without it installed?If you're not going to do it right, please don't take it out on your car!Comment
Yea I've never messed with the timing or anything. Would a failing vanos cause the motor to run rich?If you're not going to do it right, please don't take it out on your car!Comment
413 red label. With trm chipIf you're not going to do it right, please don't take it out on your car!Comment
Yea. It's an obd1 m52. I should of clarified that. Pink top injectors and I've already replaced the fprIf you're not going to do it right, please don't take it out on your car!Comment
Gotcha, does the car run any different with the MAF unplugged?
Almost sounds like a timing issue with the loss of power/backfiring.Comment
Yea it runs like shit without mafIf you're not going to do it right, please don't take it out on your car!Comment
I just went out to check the codes again and it threw an oxy sensor codeIf you're not going to do it right, please don't take it out on your car!Comment
