part number of crank sensor?
m52 power loss at full throttle
Well its retimed and has a new oxy sensor and spark plugs. Cleaned the fuel system and put sea foam through the intake. Added some fresh gas. Still does the same damn thing. Only throws a purge vlave code that I already have capped off. Time to get new can and crank sensors? That's the only thing left that I can think. Yet its not throwing a code for either one.If you're not going to do it right, please don't take it out on your car!
Mines not really an rpm kind of issue. Its just mainly wot that's not working. I thought maybe my speed sensor on my diff just shit out.
Which switch is wot? That would just be a new throttle body sensor if it went bad?
And just recently my tach quit working all together but so has my windows, blower motor, and sunroof but I don't think that's related to this issue. That's more of an unloader relay thingIf you're not going to do it right, please don't take it out on your car!
OBD2 e36 ECUs get VSS (speed sensor) from the cluster for some reason. But I see you have the OB1 m52. I'm not too sure how that wiring is done, you'll have to look into that more, but that could also be your problem.
The TPS can be tested by using a multimeter between the signal (red/white wire usually) and the ground (black). Move the throttle throughout the range while looking at the readings. Should go about between 0 and 5v. If anything is off there, it will throw off the WOT switch in the ECU (anything above 86% throttle usually)
