Help me proof my swap before I dive in
  • arch4ngel
    • Dec 2008
    • 791
    I'd skip the 944 booster and look for an e32 735i booster and master in junkyards. Cheap and supposedly much better feel (that's what I'm using though my cars still in pieces).
    Project
    Feedback
    • justin_l_
      • Jun 2007
      • 1079
      Feel is preference, personally I like the e21 booster
      • Nick_S
        • Apr 2011
        • 3656
        I believe I saw an E32 735 being parted on CL just the other day.
        91 318is M50 swapped
        05 Honda Pilot
        24V swap thread
        • rudenate
          • Jul 2012
          • 16
          Originally posted by Nick_S
          I seem to remember reading that the 318is throttle cable can works just fine? I'll look into the engine temp sensor, thanks!
          Yeah the 318is cable works perfectly. You can just use the brown engine temp sensor off of your M42 as well. Also if you're not running A/C and keep the pulley off, remember to throw some spacers on the bolts so they don't hit the timing case cover. There is very little clearance.
          • Nick_S
            • Apr 2011
            • 3656
            Good info! Thanks man!
            05 Honda Pilot
            24V swap thread
            • drummerchubbs
              • 512
              I did the same swap. I LOVE the NV in a e30.
              SEE THE MOST BORING M50NV BUILD THREAD HERE: http://www.r3vlimited.com/board/showthread.php?t=288275
              • Nick_S
                • Apr 2011
                • 3656
                Glad to hear! I've gone through your thread a few times. I'm coming from an M42 so the difference in low end torque especially should be noticeable. Last of the parts I need were ordered today (yea right, I'm sure I forgot something).
                05 Honda Pilot
                24V swap thread
                • ayemattyyy
                  • Apr 2008
                  • 411
                  A couple things:
                  Yes, 16" spal will work on a m42 rad.
                  And Nando's work isn't proven as it had a few wires crossed on mine(which I'm sure isn't the norm), but is a good step in the right direction. Just something to keep in mind.
                  Matt
                  • klodkrawler05
                    • Apr 2012
                    • 253
                    I didn't see it on your list but I'll mention it since I'm running the same flywheel (with a different clutch) and just got my swap running 2 weeks ago.
                    buy a new OEM throwout bearing, the one that came with my F1 flywheel/clutch has some chattering/squeaking like I've never heard from any other throwout before, I'm not looking forward to pulling the trans out again after such a short time of having the swap running.
                    -Brad
                    My E30: http://www.r3vlimited.com/board/show...50#post3916850
                    • butters
                      • 1202
                      Chattering, you say? Is it not simply the LWFW chatter? Not to get into a debate over the merits of a light flywheel..
                      • Nick_S
                        • Apr 2011
                        • 3656
                        Oh I'm aware of the chatter. I ordered the 14.5lb chromoly flywheel. My old SVT Focus I had a 9lb Fidanza flywheel from a 28lb dual mass. It REALLY woke the car up but chattered and sounded like a diesel.
                        05 Honda Pilot
                        24V swap thread
                        • klodkrawler05
                          • Apr 2012
                          • 253
                          Funny you mention the SVTF, I had a LWFW in my pwsc'd zx3, it didn't sound quite like this. Perhaps I'm just being too critical of the noise, functionally the car performs fine, just doesn't sound fine :) at idle
                          -Brad
                          • Nick_S
                            • Apr 2011
                            • 3656
                            Funny you have a pwsc'd ZX3. Mine was a JRSC'ed SVT. I miss that car. You happen to be on focusfanatics? I used to be a moderator over there.
                            05 Honda Pilot
                            24V swap thread
                            • klodkrawler05
                              • Apr 2012
                              • 253
                              Yup sure am. I post in the michigan people thread regularly under the same screenname.
                              Did you ever go to spring into focus or focus in the field between 07-10? maybe we've met lol
                              -Brad
                              • Nick_S
                                • Apr 2011
                                • 3656
                                Why yes I have :pimp: Sonic blue SVT with gold EAP's.
                                05 Honda Pilot
                                24V swap thread
