AKG Harness Adapter Compatibility
  • K-Line
    • Sep 2013
    • 122
    Im buying an M50 with harness, DME, and trans right out of a 525i. My question is will the AKG adapter work with the 5 series engine and harness? Also what does it mean when it says it does not support the onboard check control for the oil level?
    Thanks
  • EN318isPDX
    • Oct 2007
    • 4373
    5 series harness is shorter than E36 so you wont be able to mount ECU correctly
    • JCarp90
      • Feb 2011
      • 1759
      It will work though. That's what I used with my swap.
      E34 harness sucks balls. I wish I would have known it wouldn't mount properly when I did my swap.
      • e30austin
        • 15382
        Yes, it will work, regardless of E34/E36 harness. I recommend an E36 harness though.
        • ParsedOut
          • Sep 2005
          • 1437
          E34 harness is a little funky. Its short on the DME end and long on the sensor end. It works, but it isn't very "clean" looking IMO. The nice thing is the oil level sensor is built into the harness.
          • K-Line
            • Sep 2013
            • 122
            Looked on ebay and it looks like i can sell the e34 harness and pick up an e36 harness for the same price, I assume I can directly swap the e34 harness with the e36?
              • 34844
              Its easier to add the level sensor wiring than deal with all the other problems. Its not worth it for that one thing.
              I agree, the E34 harness sucks.
