s50 piston clearance
  • benz-tech
    • Jan 2011
    • 365
    I need the piston-to-wall clearance for a 96 S50 engine (to bore my M44 accordingly) since I am sending the block and pistons out to the machine shop tomorrow.
    I googled with no luck.
    I could use a link to some real BMW service manuals for M44 and S50 specs if anyone knows where to get that.
    Thanks, 2/3rds of an m3 (E36) is on its way into my E30. Maybe I should fab up an M2 badge. umm no.
    You say "Where are your other two cylinders?"
    I say "Where's your other camshaft?"
    Frankenmotor: if an M42, M44, M20, S50, and S52 were to have a kid.
  • Steven
    • Dec 2012
    • 2305
    First off, a 96 is an s52.
    Second, when I was rebuilding my engine I googled it and found it in no time. Just try different search terms.
    Might be useful for you:
    http://whatismycar.com/files/bmw_bol...ifications.pdf
    Feedback!
    Custom Cup Holder Consoles!
    Calypso Story--S50/Shaved and Tucked Bay
    • Paradox
      • Jul 2010
      • 337
      Piston to wall:
      .0034
      Top ring:
      .019-.020
      2nd ring:
      .024
      oil ring=minimum = .015"
      • benz-tech
        • Jan 2011
        • 365
        that did it, thank you. it has everything I need. I did verify that my pistons are S50 but I guess I have the year wrong. They are 85.9mm
