s52 obd1 zf + 4.10 lsd anyone?
  • vitiokas95
    • Dec 2013
    • 482
    #31
    Originally posted by Wasefi
    Hey where did you buy the diff cover from and how much was it??
    VAC motorsports. around $400 shipped.
    1990 e30 325is S50 swap (NASA GTS2 race car)
    1990 e30 325is
    1988 e30 M3 S50 euro swap
    • vitiokas95
      • Dec 2013
      • 482
      #32
      So my set up now will be 3.73 LSD since 3.25 I bought before turn out to be non LSD.
      Also I will be running 215/40/17 wheels
      1990 e30 325is
      • WannaBe30
        • Feb 2013
        • 295
        #33
        3.73 isn't that great I'm running a 3.46 now because the 3.15 locked up someone forgot to put oil in it
        I'm still shooting for 3.23 94 3.15 for a perfect serup
        • Wanganstyle
          • 2828
          #34
          The perfect factory setup is:
          Zf 5 speed and 3.15 or 3.23.
          Tires between
          225/45/17
          235/40/17
          245/40/17
          Almost everything bmw equips with a 5 speed non overdrive 5th gear has a 3.15 or 3.23 final
          E34 525i NV zf310 has 3.23 final
          E34 525i g250 has 3.23 final
          E36 g250 325i has 3.15 final
          E46 g250 325i has 3.15 final
          E36 m3 zf310 has 3.15 final
          E36 m3 zf 320 has 3.23 final
          E36/7 z3 2.8 has zf 320 and 3.15 final
          E36/7 z3m s52 zf320 has 3.23 final
          E36/7 z3m s54 zf320 has 3.15 final
          • Poeman446
            • Jun 2013
            • 227
            #35
            I have an OBDII S52, ZF trans, and a 3.73 LSD. Its insane, and I only just ran it last weekend. I'm swapping to something reasonable now. The 3.73 is absolutely insane. You can roast tires on command in second gear, and probably burn a little in third, but I haven't tried. I have a 3.23 from the E36 M3, and I want to fit it under there, but ill end up going with a 3.25 or 3.15 to be more simple.
            • Chris916
              • 183
              #36
              S52 zf 5 speed with 4.10 was my setup last year. It wasn't as bad as you think but a 3.75 for track would definitely be the way to go. Not sure for a street car.
              I'm also running 255/40 17's so that helps the shorter gears
              This will give you an idea how it was:
              • MyE30
                • Sep 2013
                • 326
                #37
                Nice driving but that was very unsafe to keep driving after your rear view popped off and was dangling in front of your face like that. I'm sure it would have been just as easy to drive down pit lane and pull it off and only loose minimal time. In a "gentleman's race" (is that what they are calling DE days now?) there is no prize worth being unsafe like that.
                Either way, the 4.10 seemed pretty nice on that track.
                • E30Runt
                  • Jul 2013
                  • 46
                  #38
                  Reading this thread has me excited and potentially worried about my swap. M52/ZF + 3.91. Still a ways out but should be interesting. DD and track time at Thunderhill and possibly adding Auto-X.
                  1984 AW 318i - aka Runt
                  • Neil1138
                    • 527
                    #39
                    I have an S52 > ZF 320Z > S3.73. Lots of fun in the city but revs too high on the highway. I'm around 4k RPM going 70mph. Not very practical but then again, the e30 isn't my daily.
                    Would not recommend S3.73 or anything higher. My plan is S2.93 + boost.
                    • MyE30
                      • Sep 2013
                      • 326
                      #40
                      what size tires are you running?
                      • agent
                        Vice Grand Pubaa
                        • 7960
                        #41
                        Originally posted by agent
                        A 3.15 on 16s is just about perfect for mostly street/occasional AutoX use.
                        Tires between
                        225/45/17
                        235/40/17
                        245/40/17
                        For the record, there's a 1.3% difference in rolling diameter between that middle choice and a 205/50-16.
                        I'm at about 3300 RPMs running 75 on a 3.15 Torsen in 5th (ZF320).
                        Originally posted by kronus
                        • Pocket Chant
                          • Mar 2012
                          • 403
                          #42
                          Just put an S50 into my 325is with a 3.73, top speed is 130, with it bouncing off the fuel cutoff. 80 is like 4500 in 5th
                          1987 325is, S50B30US, Kamei side skirts, Zender Spoiler.
                          MT2 Wheel, 95 M3 Rack, Condor Speed Shop knob, UUC SSK w/ DSSR, Billy Sports/GE Coilovers, KAMotors CAI.
                          Originally posted by MclubSport
                          Why you have a badge on wheel ? You do not know what car you have? But if you have a mustache, you know better where is your mouth?
                          Horrible with responding to PMs, I'm so sorry.
                          • gazil
                            • Oct 2012
                            • 250
                            #43
                            I am doing a s52 swap and I have everything from the m3. The car is a 1996 m3 coupe and I thought that the diff does not bolt on directly
                            Originally posted by matthugie
                            The 3.25 will be a good ratio, but the diff isn't plug and play from e36 to e30 unless it came from an M coupe or roadster.
                            1989 325i Sold
                            2001 325i Sold
                            2005 Infiniti G35 Sold
                            1991 318is Rip
                            2005 Subaru Sti Sold
                            2009 Honda Civic SI Sold
                            2009 Honda Civic Si Sold
                            2003 Saab 9-5 Sold
                            1991 325ic MTech2 S52 Current
                            • ArtClassShank
                              • Jul 2013
                              • 143
                              #44
                              It doesn't. He's talking about the Z3, very similar to E30 in the rear section.
                              1989 Carbon Black 328is
                                • 34834
                                #45
                                But the internals swap into an E30 case.
