valve tick after donuts
  • iloveshaorma
    • Feb 2012
    • 59
    After 2 3 donuts i can hear valve tick like on a m20. It does that for 20 30 seconds then it shuts up. I have a m52tub25. Chaned the oil 4000 5000km ago with motul xcess 8100 5w40. I cut all the oil pans windage trays and a bit of the m52 trey so that i can fit the pan. Could that be the cause? Oil pressure switch does not light up. Could it cause bigger damage?
  • DesertBMW
    • Aug 2011
    • 1034
    slight rod bearing wear or bad valve lifter.
    • hendrixvodu
      • Jan 2007
      • 2514
      Vanos rattle, failing chain tensioner, sticky lifter could be a number of things
      -His-
      87 e30 325i
      87 e24 m6
      05 e83 x3
      94 e32 740i 5spd
      -Hers-
      89 e30 325i
      18 f48 x1
      • MR E30 325is
        • Dec 2008
        • 3300
        I would be more helpful if the rpm range was given during burnouts.
        Are you talking about bouncing off the revlimiter most of the time, or can you control the go pedal well enough to maintain a more solid peak rpm?
        Length of time of donuts as well. Oil starvation is a real possibility depending on how long the donut lasts and the path and position the engine experiences.
        My previous build (currently E30-less)
        http://www.r3vlimited.com/board/showthread.php?t=170390
        A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
        • kronus
          • Apr 2008
          • 13032
          most likely lifters if it goes away after idling for 30 seconds, that's them refilling after getting starved.
          cars beep boop
          • iloveshaorma
            • Feb 2012
            • 59
            no burnouts just donuts, if i race it or do burnouts it does not happen, only if i do donuts i kept it 1st gear at about 4-5.5k range gently, it happened some time ago when the temp gauge was still on blue but i figured it was because the oil was cold and thick. a similar situation was on cold starts, i had Mobil 10w-40 oil and when i cold started it the lifters were noisy for 7-10 seconds then they would shut up, i tried cranking it without it starting to build the pressure but still happened. could the oil starve when doing donuts not cause the oil pressure light to come on?
            • KoKoSe7eN
              • 253
              It's the windage tray, it's needed so the suction tube gets minimal exposure to air/starvation of oil. Your pressure switch my not turn on as it's not sensitive enough to fluctuations of pressures... E30s oil pressure switch opens above 2.1 psi as it shows in bmw diagramshttp://www.armchair.mb.ca/~dave/BMW/e30/e30_91.pdf page 34... But having just a little air in the system could cause lower pressures to the lifters which will cause the ticking until air has purged out of the passages... Which is why we see cars in racing or cars that experience long durations of g-force need upgraded windage trays or dry sump systems to maintain proper oil pressures
              91' MtechII AW/SW BAR'd S52/SC
              • berlow94
                • Jan 2013
                • 1063
                Cutting out the windage tray certainly isn't going to help you...
                The best one-stop shopping for German car parts and lifestyle: http://www.gutenparts.com/
                • Vtec?lol
                  • Dec 2009
                  • 3278
                  You need to add a little more oil since you've cut the trays.
                  KoKoSe7en has your reason why.
                  Dem G's
                  • DER E30
                    • Sep 2013
                    • 2349
                    Yup, you're starving the oil pump with the G forces of the rotation. That's why it's ticking... just about every bearing in the motor hates being starved...
                    -Christian
                    • e30rapidic
                      • 2167
                      a donut is a burnout, just in a circle. You're sloshing the oil around and probably sucking in some air.
                      '87 325ic, powered by S50.
                      • iloveshaorma
                        • Feb 2012
                        • 59
                        Thanks for the answers guys. Too tired to take my pan off and fab a windage tray...
