Hey guys, I've been searching (and will continue to do so) and I really didn't want to ask, but --
02/87 325e
03/95 S50B30 US
94 325i Manual Vanos Harness
AKG wiring adapter
Both grounds on the engine arms are hooked up
distribution block is correct
Fuel rail is grounded
engine was timed with the correct factory tools
The car cranks, but the fuel pump isn't turning on and I don't have spark.
CPS checks out according to bentley
ICV doesn't hum
I can jumper the fuel pump relay and it works, but still doesn't start. I just spliced pin 7(body) to pin 21(harness) because the AKG adapter doesn't have it.
few questions: I plugged everything up, but all of the information I found said that the IAT under the manifold used a 2-hole plug with 1-wire to it, I thought that would go to the E30 temp sensor I installed in the head?
am I looking at this harness adapter just not working for my car, or am I missing something simple?
02/87 325e
03/95 S50B30 US
AKG wiring adapter
ICV doesn't hum
I think it's an EWS feature that shouldn't be existent. It started momentarily on starting fluid last night, and I bench tested all of the injectors and they check out.
