Yeah, I had a very similar issue with my car after my dme got wet. I replaced the dme with another red 413 and had same issue till I unplugged the ews and plugged it back in, then it started, and that seems to be the cure so far. Hopefully it's just a bad dme in your case, not getting fuel or spark. There is a guy on here that has like 30 of the red 413's. His user name is flash. Get in touch to get a pre 1995 dme
S50 Crank no start
I had a similar issue on a 318is a few years back with wiring issues. It turned out that somehow a little green loop wire under the dash got unplugged and wasn't providing power to the unloader relay. You might look into that...?'70 911s | '72 2002 | '88 M5 | '89 330is | '89 M3 | '95 911 | '02 M5 | '04 RR HSE
