my m50 swap in progress... pics (no 56k)
  • DanGillan
    • Mar 2004
    • 4061
    Originally posted by permit
    $200? Impressive. You'll be quite happy with that motor until you can get an S50, then all hell breaks loose.
    yea, a friend hooked it up very well. and damn straight. i just got a ride in an s50 e30. i know this m50 is not enough, but once this gets running, i can buy a high mileage s50 and take my time rebuilding it while i enjoy this m50.
    Dan
    • E30-323ti
      • 328
      A non-vanos M50 is the perfect base to go FI from, nice meaty rods!!
      292rwhp E30 :D
      • DEV0 E30
        • Oct 2004
        • 8890
        Perfect plan dude.
        • BimmerToad
          • Sep 2004
          • 1537
          Killer price. You'll enjoy the outcome.
          San Diego BMW repair -> Jake @ www.littlecarshop.com Great guy :up:
          • DanGillan
            • Mar 2004
            • 4061
            Day 3:
            Only had about an hour to work at the shop, we dismanteled the m20 and found some interesting stuff floating around in the block area... :)
            I kept the oil pan, head, intake manifold and a couple other small parts to sell off and put the heart of the m20, the thing that fucked me over... the block into the dumpster, where an m20 belongs.
            I also picked up the wiring harness today, and the necessary items to make the wiring adapter, and have tested all my pins and used addissimo's chart, a few things were different, but its all labeled and ready to be sodered and wrapped into a nice plug and play engine adapter. easy as pie. i just finished labeling and testing, ill put that together tomorrow, its 12:30.... i have class at 8 :(.
            tomorrow the power steering comes out and gets replaced with new tie rods, lines and resovoir, all the AC components come out, cruise control comes out (stopped working a while ago, didnt use it ever anyway), and the new SPAL electric fan gets wired up :) the driveshaft will get a new guibo and center support bearing as well. i hope i can get all that done tomorrow night. ill keep updating, ill be staying busy, hope to have it running this weekend, next the latest as long as my booster's shipping doesnt hold me up :(... thanks,
            -Dan
            Dan
            • E30_pilot
              • Sep 2005
              • 1461
              Day 3:
              OUCH!!!
              Keep us updated with all the details,might be considering
              doing the swap also ;)
              -Frank
              1987 325is m50nv (schwarz)
              1990 325is (sterling silber)(sold)
              2001 525i
              • Bimmerfanatik
                • May 2004
                • 5349
                Good luck with the harness - that thing is the cleanest, nicest harness I've seen - uncut, ready to go. Plus, it's an e36 harness, which should make the install a bit easier/cleaner.
                Don't lie dan - you style your hair before leaving the house, regardless of whether or not you're working on cars - at least you've got hair to style, unlike me...
                I still can't get over the low mile, e34 non-vanos m50 out of an auto touring. That's the PERFECT engine - one I had been looking for! Oh well...
                Nice pics. Keep them coming. I was always convinced that if my engine shit the bed I'd go M50 in a crunch like this - I know it can be done and for relatively cheap. I do have to applaud you for that laundry list of new maintenance parts you bought - you may be doing it on a budget, but you're doing it right. Nice work man.
                If you need any help, give me a shout - I'd like to check this out.
                PS - rode in Alex's euro s50 touring - talk about e30 heaven... ;)
                • DanGillan
                  • Mar 2004
                  • 4061
                  Day 4: (pics at bottom)
                  I stripped the AC because to run it in the e30, since its the m50 compressor requires custom lines. Andy welded up the OBDII manifolds in like 3 seconds flat. i removed the o2 sensors from the manifolds and used an o2 sensor bung in their place. did maintenance items on the motor (exhaust gaskets with the manifolds, tstat and housing, plugs, belt, e36 motor mount arms, etc....) and pressure washed the engine bay one more time (its still not pretty) Got the booster in today as well as the rest of the parts i ordered, all i need is the ECU, if anyone has a non vanos ecu please PM me, thanks!!
                  the stripped of everything un necessary engine bay...
                  the junk that came out...
                  the new manifolds...
                  OBDII nice OBDI suck...
                  -Dan
                  Dan
                  • 325Projectz
                    • Jan 2005
                    • 1956
                    :up:
                    You're going to love that non-vanos with a fresh head! Especially with the 4:10.
                    How much lighter are those OBDII exhaust mani's compared to the OBDI's? Same dimensions?
                    91 m3
                    • DanGillan
                      • Mar 2004
                      • 4061
                      i know i cant wait to drive the car at this point. it wont keep me satisfied long. s50 is already breathing down my neck.
                      mani's are the same dimensions, just stainless steel tubular welded instead of cast iron, they weigh a little more than half of what the iron ones do, probably just about half the weight.
                      Dan
                      • permit
                        • Mar 2005
                        • 3363
                        OBD-II ones have a longer down pipe...it almost hits the subframe on e30s.
                        Score, I still remain one of like, four people in the world with A/C on a 24v e30.
                        • DanGillan
                          • Mar 2004
                          • 4061
                          they still fit from everything i've seen we put them on the e30 m3 24v and they cleared, you thinking they wont clear on my car?
                          that's awesome about your AC, frankly im slightly jealous, how did you run yours?
                          Dan
                          • FredK
                            • 14761
                            That's a lot of progress in just a few days!
                            I guess I have a thumb up my ass because I still need to get a EWS delete chip, and pretty much all of the swap parts except the oil pan. Haha.
                            • FredK
                              • 14761
                              I think the AC requires one custom line and a hose from a 318is or something. Probably a good idea if you're gonna use the car for a little while before you go S50.
                              • Jarvis
                                • 2132
                                Just find the right wire in the harness, and cut it. Same effect as a delete-chip.
