Want to make 20$??
  • P33G
    • Nov 2013
    • 53
    Want to make 20$??
    Long story short me and a friend are both trying to do s52 swaps into our e30s, unfortunately we both are idiot's and can't seem to find a complete list of EVERYTHING we need for the swap, so if anyone is willing to post a complete parts list for an obd2 s52 swap then i will paypal the first person with a complete list 20$ us. thanks for the help!! (probably going to get flamed for this but this is really our last resort lol)
  • dirtbag30
    • Apr 2013
    • 678
    keep your money and read
    i have no idea what i am doing with my life
    • Poeman446
      • Jun 2013
      • 227
      Indeed, keep your money. It all depends on what YOU want to do. Start with the S52, the wiring harness and the ECU for it. Do you want to relocate the brake booster or go with a different one? How do you want to run your exhaust? it all depends brother. plan your own swap, and youll be happier with it. I recommend going with a late E30 radiator and expansion take if you have an early model car. I also highly recommend the long tube headers from ebay for the s52. they will be about $100 shipped. Im going to make my parts list soon for what I used, so when i finish it, ill send it your way.
      • uturn
        • Dec 2010
        • 1006
        Since you got your list x3, I'm going to expect a kick-ass engine swap write up soon!
        • uturn
          • Dec 2010
          • 1006
          I've read about a few different approaches to the brake booster issue.
          1) E21 booster/porsche 924/944 booster
          2) 325ix booster
          3) shifting the booster to the left
          4) booster delete plate by Massive
          • Poeman446
            • Jun 2013
            • 227
            I relocated my booster, but I have a lot of tools at my disposal. If you don't have a lot of tools, I would recommend taking a different "bolt-on" route. I should write a swap thread... I didn't document mine nearly well enough. I'm typing up my excel cost spreadsheet now.
            This is one of the best resources out there:
            • efficient
              • Feb 2012
              • 3312
              http://www.e30dohc.com/wiki/index.ph...HC_Swap_Basics
              Your link doesnt work
              • Slovik
                • Jan 2010
                • 198
                Here is my list with part numbers and cost, this was for a 91 318is using the 240 tranny. You can get away with spending less or more, this is just how I did it. Keep the $20 your'e going to need it.
                S52 Conversion Cost
                Parts Source Part # Cost
                98 s52 Engine Craigs List $1,800.00
                A/C Compressor Ebay used $101.00
                Repair Manual Disk Ebay $9.99
                Oil Pan 92 BMW 525i aaforeign.com $95.00
                Brake Booster Porsche 944 Turbo Ebay- used $59.95
                Water Pump Ebay- new $41.92
                Bentley E36 Manual Amazon $50.37
                Haynes E36 Manual Amazon $16.47
                Alternator 140 amp- 98 M3 Carguts.com Carguts $45.00
                Power Steering Pump 95 325i Carguts.com Carguts $35.00
                Steering Rack 98 318i Carguts.com Carguts $40.00
                Truck Rental Enterprise Enterprise $77.26
                Mass Air Flow Sensor Ebay - New $64.95
                MS 41.1 M3 ECU Ebay - used WBSBG9330WEY79583 $150.00
                Air Intake Boot Non ASC 13541703588 $32.15
                Control Arms
                Tree House Racing Eyeballs Used $100.00
                Replacement Inserts for THR Eyeballs Tree House Racing $10.00
                Z3 Differential 3.45 Carguts.com $199.00
                E36 Driveshaft Carguts.com 92 thru 99 M/T 26111227445 $75.00
                F1 Stage 2 Clutch Kit Ebay- New $182.00
                Shift Linkage getbmwparts.com 25111220759 & 25111220835 $44.11
                Engine Mount Arms Ebay - used 11811141137 and 11811138249 $62.90
                Engine Mounts E28 535i (2) autohausaz.com 11811132793 $45.42
                C101 Connector and Pins getbmwparts.com 12-52-1-707-283 & (20) 61131376193 $24.90
                X20 Connector ebay - used $29.00
                E34 Dipstick and Tube ebay - used 11431720875 & 11431738169 $35.90
                Weld Headers $100.00
                Reprogram Computer TRM $210.00
                ICV Hose from Intake getbmwparts.com 13541740159 $10.06
                88 degree Behr Thermostat autohausaz.com 11531721002 $19.83
                Thermostat Seal autohausaz.com 11531250399 $0.63
                Radiator & Other Hoses
                Overflow Tank E30 325i U-Pull-It (Rock Hill) $15.00
                Oil Pickup E34 525i getbmwparts.com 11411748150 $22.40
                Oil Pan Gasket & Dipstick O Rings autohausaz.com 11131437237 & 11431287541 $20.14
                E30 Coding Plug for Tach Ebay - used $21.09
                Brake Master Cylinder (Rebuilt) Rock Auto A-1 Cardone $81.99
                Air/Breather Hose Connector autohausaz.com 13411722944 $0.68
                Accessory Belt Tensioner Pelican Parts 11281717188 $60.50
                Belt Pulley / Rollers (2) autohausaz.com 11281748131 $28.34
                Exhaust manifold Studs (4) autohausaz.com 11121744057 $1.84
                Coolant Temperature Sensor (Brown) autohausaz.com 12621710512 $6.61
                Serpentine Belts (2) autohausaz.com $26.51
                Oil Filter (Mann) autohausaz.com $7.08
                Exhaust Manifold Gaskets (2) Pelican Parts 11621744252 $14.50
                Intake Manifold Gaskets (2) Pelican Parts 11611740069 $14.00
                Clamping Ring with Threaded Ring for Drive Shaft Pelican Parts 26117514037 $9.00
                Exhaust Manifold Gasket to downpipe (2) Pelican Parts 18301716888 $2.50
                Crankshaft oil seal cover autohausaz.com 1.11141E+11 $1.56
                S52 Rear Seal autohausaz.com 11141706785 $9.44
                M20 Flywheel Highoutput - Matt Machined for S52 $100.00
                Starter e30 325 Carguts.com $21.60
                Wire Harness for Manual Transmision M3 Ebay - Used $100.00
                M50 Fuel Rail U-Pull-It (Rock Hill) $14.93
                M50 Intake Manifold U-Pull-It (Rock Hill) $21.00
                M50 Hard Lines (fuel) U-Pull-It (Rock Hill) $3.00
                Modify Engine Harness Markert Motor Works $180.00
                Clutch Hose Autohausaz.com 21521156673 $32.37
                Power Steering Reservoir Rock Auto 32411097164 $14.38
                Throttle Cable for 525i M50 Bavarian Auto 35411160609 $27.95
                Dot 4 Brake Fluid 32oz Advance Auto Parts $8.55
                Clutch Fork autohausaz.com 1 21511204229 $10.42
                Clutch Fork Spring Clip autohausaz.com 1 21511204327 $1.84
                Clutch Pivot Ball autohausaz.com 1 21511223328 $1.34
                Manual Trans Output Shaft Seal; 40x55x8mm autohausaz.com 1 23121222771 $2.95
                Input Shaft Oil Seal; 30x50x7mm autohausaz.com 1 23121222972 $3.63
                Hood Pad / Foam Pelican Parts 51481972245M9 $63.74
                Valve Cover Gasket Pelican Parts 11120034108M17 $21.25
                One way valve for brake booster (Porsche) Pelican Parts 191-611-933F-M100 $13.75
                Gromets for Valve Cover Gasket (15) Pelican Parts 11121437395M17 $15.00
                Mobil One ATF (2 Quarts) for Transmission Autozone $21.28
                12 Fuel Injector O-Rings Advance Auto Parts $4.80
                Flywheel Shim Ring Bavarian Auto 11221262827 $33.90
                Fuel Pressure Regulator Pull-A-Part $11.00
                M3 Downpipes ebay - used $54.99
                A/C Hoses from e36 for Compressor Ends Pull-A-Part $15.50
                Crankshaft Seal Kit Blunt Tech 11142247867 $102.93
                Power Steering Hose E36 Pressure Side Pull-A-Part 32411141953 $3.11
                Bushing for shift arm 25117519669
                Coil Rail Cover Trim Pieces 11121726089
                Custom Built Exhaust System APS Muffler - Rock Hill, SC $500.00
                Trim Panel to cover wire harness ECS 51711380392 $15.41
                Inner Fender Brake Duct (Right) ECS 51711962768 $11.00
                Aluminum Radiator E36 CX Racing $124.50
                2 x 10 Slim Puller Fans DNA Motoring RAF-10+FMK-x2 $43.99
                Derale Electric Fan Controller Switch North Coast Performance 16738 $30.90
                • P33G
                  • Nov 2013
                  • 53
                  Thanks for the links, slowly getting more info. most are those are obd1 and i'm trying to keep the exhisting obd2. i appreciate the links though!
                  • P33G
                    • Nov 2013
                    • 53
                    Thanks for the reply, so far me and my friend both have s52s (i'll be picking mine up next week) they both came with all accesories ,wiring harness,ecu etc also they have zf trannies and came with m3 drive shafts. I have a 91 318is and my friend has an 85 318i. not 100% sure what i want to do for the exhaust.so far with the info provided for you guys i have been able to come up with a short list of parts that are needed. If you see something that is missing or wrong please let me know, we are trying to keep obd2!
                    s52/zf
                    e36 m3 drive shaft
                    3.25 lsd
                    E34 M50 oil pan
                    E34 M50 oil pickup tube
                    E34 M50 dipstick tube and dipstick
                    E34 M50 oil level sensor
                    E28 535i arms
                    condor speedshop mounts
                    ebay headers
                    e34 m50 throttle cable
                    electrical puller fan - SPAL 16" pusher slim fan
                    e30 brown top coolant temp sensor
                    m50 manifold conversion kit?
                    obd 1 fuel rail and fpr
                    ecu tune- rear 02, SAP, EWS, fuel tank sensor, muffler flap valve?
                    thats all I got right now, there is more but I'm pretty lost to be completely honest. any help is appreciated!!!!
                    • P33G
                      • Nov 2013
                      • 53
                      Hopefully man haha!
                      • P33G
                        • Nov 2013
                        • 53
                        2) 325ix booster
                        trying to go with the easiest route possible that will retain good brake feel. I daily my car, so a brake booster is a must.
                        • P33G
                          • Nov 2013
                          • 53
                          Yeah i'm trying to take the easiest way out. a friend of a friend is doing my swap one weekend, so i'm trying to gather all the parts i need to get it done "smoothly"! if only that link worked :/ ! would you mind sending me that excel sheet when your done with it? i'm trying to see what everyone did for prep/parts.
                          • P33G
                            • Nov 2013
                            • 53
                            what would change from the list with using the zf transmission? I really appreciate you sending that my way man, thanks!
                            • Poeman446
                              • Jun 2013
                              • 227
                              I reflashed my own ECU to keep OBD II. The muffler flap valve, fuel tank sensor and all of that is horse shit from what I've seen. (it is contained within the values of other things that you already change... and this "extra modification" costs you $50 each to get rid of when you literally do not modify different bytes of code. I'm no expert on this, but mine works fine so far with no CEL's. I did actively erase the SAP section of the code, the EWS driveaway protection and the rear O2 sensors. I wrote a thread on how to reflash, but you'll need an OBDII E36 to plug your ECU into to reflash and a cable or two, or make your own bench rig. I'll tell you what, If you aren't in a huge hurry, (the next month or so) I'll rebuild a bench rig and reflash your ECU for you for cheap. I need to get into that again anyway. If you need it done quicker than that, be sure to shop around. PM me and I'll send you to the right people.
                              As for some other things. The link that "isnt working" due to a copying error, is in one thread that dirtbag30 sent you, as the first links in the first post. Just google "e30dohc wiki" and you'll find it.
                              If you go with the ZF Trans, you don't have to modify the shifter support arm and rotate it 10 degrees. If you stick with the 260 trans, you can I believe use the E30 Driveshaft, and you can definitely use your rear diff if its a lsd and you like it. But you need to modify the shift linkage and twist it 10 degrees. You can use the standard E30 manual trans brace with the ZF, no modification needed.
                              I attached a .pdf version of my excel spreadsheet so far. This definitely doesn't include all of the little things I bought like wiring shrink wrap, connectors, etc, but its a good start. Some is not necessary for the swap, like my suspension setup. I hope this helps.
                              I feel like some of this wasn't clear. I'm sorry if its not, I'm pretty tired.
