Markert Motor Works Dyno Thread (many inside)
  • TheAxiom
    • Sep 2015
    • 59
    #346
    What is up with your E90 325i? The 3 stage tune doesn't seem to account for all the DISA valves...otherwise good stuff as always.
    E92 Msport
      • 34847
      #347
      it's definitely a 3-stage based file - I helped him set it up. IIRC the car is a high miles automatic.
      • TheAxiom
        • Sep 2015
        • 59
        #348
        If that's an automatic, that's even more impressive.
        E92 Msport
        • 328ijunkie
          • May 2007
          • 3961
          #349
          6AT with 238k miles :)
          Check Us out on Facebook
          Full Product Line Tuning
          • Jb325is
            • 2137
            #350
            Dang I was about to be really sad before I saw the post-cam sensor fix run on the m54 Ti. Mine feels about like the first graph though
            - '88 m54 coupe
            <3
            • TheAxiom
              • Sep 2015
              • 59
              #351
              Wait a second, I know whose car this is. It looks like it's running transmission software (hence the ability to hold gears and a higher red line) You're in GA - so maybe someone from Bimmer Geeks.
              Don't ask me how I knew, but it just hit me.
              Impressive stuff.
              E92 Msport
                • 34847
                #352
                Different cars - I don't think he has a 6at flash but we'll have to fix that. :)
                • TheAxiom
                  • Sep 2015
                  • 59
                  #353
                  He does I believe, but this looks like good stuff. No valvetronic limiter, 4 stage DISA disabled, proper DISA set points. Good work - now test out those lift adjusters.
                  E92 Msport
                  • 328ijunkie
                    • May 2007
                    • 3961
                    #354
                    I don't have a trans flash. Different car ;)
                    You can hold gears to redline on stock flash just fine if you hold the shifter or paddle. It will even bounce off limiter
                    • TheAxiom
                      • Sep 2015
                      • 59
                      #355
                      ON the 3 stage dyno, what's the reason for no first stage DISA activation? You can see it's present in the first dyno (Pre) but not after you tune.
                      E92 Msport
                      • 328ijunkie
                        • May 2007
                        • 3961
                        #356
                        One of them codes occasionally. Prob that one. Plumbers always have leaky pipes.
                        • spiDmang
                          • 3941
                          #357
                          sent you guys an email about reflashing my 02' M coupe Clownshoe....Has a Shark tune on it, but it sucks ass, and the car isnt running right
                          91' 318iS - S54/6MT Swapped
                          08' E90 M3 6MT - Daily
                          Originally posted by IronJoe
                          Originally posted by 2mAn
                          • M-technik-3
                            • 18946
                            #358
                            Dave you guys offer remote tuning correct?
                            • 2mAn
                              SeƱior Mod
                              • 21085
                              #359
                              Tuned a modded High comp stock cam 2.5L M20 was running 98 octane
                              How high was the compression on this? Thats pretty damn impressive
                              Simon
                              Current Cars:
                              -1966 Blue Boat
                              -1969 Red VW
                              -1986 White BMW
                              -2006 Green Thing
                              Make R3V Great Again -2020
                              • M-technik-3
                                • 18946
                                #360
                                High enough to use 98 octane which smells so great. 12.5:1 I'm gonna guess.
