S50 vibration at idle normal with urethane mounts
  • M3PO
    • May 2012
    • 537
    I've searched and I think I know the answer but I'd like some confirmation.
    My S50 seems to be running and idling (6-700 rpms) properly and I'm getting quite a bit of vibration at idle. I've got AKG urethane mounts and IE urethane trans mounts (both are the softer versions). OEM Sachs clutch kit with F1 Racing 14 lb chromoly FW.
    I have to live with it, raise the idle, or change the mounts correct?
  • sharky
    • Jan 2005
    • 2672
    with the solid trans mounts you will get vibration. If you use rubber with enforcer cups you will be much happier. I cant stand poly trans mounts on a street car.
    • M3PO
      • May 2012
      • 537
      That seems to be the consensus. The vibration is mostly due to the trans mounts?
      • justin_l_
        • Jun 2007
        • 1079
        Yea, I would never do it if it was a daily. I don't even like them in my weekend car.
        • ian e30 318is
          • Mar 2007
          • 1809
          How much is "quite a bit" of vibration? I have AKG mounts and my car vibrates a little but it's definitely not bad. I recently changed my plugs from NKG coppers to platinums and the vibration was noticeably reduced along with a smoother idle. That is a relatively cheap option you could try.
          1991 LS1 Swapped 318is
          Instagram:
          https://instagram.com/saltybeast/
          LS Build Thread:
          https://www.r3vlimited.com/board/for...s-e30-ls1-swap
          • mtech325
            • May 2008
            • 572
            AKG poly motor mounts don't vibrate horribly (tried m20, 24v e30, and even e36 application), so my guess is the trans mounts are the culprit. Like sharky said, get the e21 rubber mounts with the enforcer cups (just did this to mine and they're working out pretty good so far...). AKG even sells them for like 75 bucks with the cups.
            --Joey
            • M3PO
              • May 2012
              • 537
              Enough that things rattle in the car. I can "see" the vibration in the mirrors.
              The car has brand new Bosch copper plugs, the OEM ones.
              • ian e30 318is
                • Mar 2007
                • 1809
                I definitely noticed a difference between the two plugs. I would also try the rubber trans mounts with metal cups as mentioned above.
                Instagram:
                LS Build Thread:
