Ok, I have the e34 wiring harness which as been a PITA since day one. I am also using the sliver 413 ECU.
Heres the deal, I keep getting a speed sensor code. My speedo works, which makes me think its the connection between the speedo and the ECU.
Looking at the ETK, according to the 91 e34 with the m50, the ECU wiring harness gets the speed signal sent to pins 67 and 68.
If I look at the e36 ETK, it says pins 67 and 68 are not used, and I cannot find ANYTHING about a speed input anywhere on the ECU diagrams. The only thing I see is in the wire chart that says "Vehicle Speed Sensor" on pin 42, but its only listing the one wire, that says its an input from the cluster.
WTF?
WTF?
