fuel consumption is from the ecu. It controls the mpg in the dash iirc. The c104 i believe was only 86-87 models under the dash in the glove compartment. They integrated it in the c101 in the engine compartment in 88. You might not even have one. But its a 3 wire connector right next to the ecu.
Speed sensor, no clue whats going on.
You can run it through the green.red wire and it should work. What I preferred to do was get the plug and pin and add it in the plug that the green/red wire goes into on the cluster. Then it was the white/black or black/white wire from the DME. I dont know the pin #.Im now E30less.
sigpicComment
I did use the green/red and I also tried the yellow one for kicks. Green/red still gave me the speed sensor code.
I think yellow is the fuel consumtion rate, but that one didnt work on the OBC like it should either.
I did some searching, and found this
Pin #1 Black Wire-Engine speed
Pin #2 green wire-OBC Fuel cut function
Pin #3 Yellow/White wire-Fuel rate
I hope black is not the speed wire, I have that hooked up to my tach, thats what THR said to do.Rollin' with a GeistkuchenComment
Ohhh, from the 2 pin thing?
none of those are vehicle speed. The black wire is engine speed (aka tach). You have to run a whole new wire from the plug on the back of the cluster itself to the engine controller. There is no vehicle speed signal for the DME on motronic cars.
That is why its so rediculous when people say, "I am certain I have a speed limiter."Im now E30less.
sigpicComment
Ahhh ok. Right now I do have that green plug on the cluster with one waire connected to it. I hve been looking at the ETK and I cant figure out what wire it has to be, would that be the one?
Thanks againRollin' with a GeistkuchenComment
The wire currently going into the green plug is the signal for the cruise control. Just get another plug and plug it into one of the other 2 and you will be fine.
Its an issue neglected on EVERY online document.Im now E30less.
sigpicComment
Can i just tap into the existing wire? Because I did. I couldnt find a plug that would fit in there.Originally posted by Ryan StewartThe wire currently going into the green plug is the signal for the cruise control. Just get another plug and plug it into one of the other 2 and you will be fine.
I dont have cruise anymore anyways, if it would make a difference.Rollin' with a GeistkuchenComment
curious if you got this figured out as i have the same problem. cuts out anytime i put my foot down past 3/4 throttle. I'm assuming the same reason cause i pull the same code...
let me know if you fixed it1990 325i - Brilliantrot, 3.73 LSD, H&R Race Springs, Bilstein Sport Shocks, 4300k HIDs, Rebuilt with Metric Blue Head bolts, Planning turbo with MS by end of the year...
2006 R6 - Raven, Driven 520 1,2 Chain Conversion, 6000k HID's, DB Screen, Heated Grips, GYTR CF Slip-on, Fender Eliminator, Flush mounts
(wife's)
1992 325i - Alpineweiss II, H&R Sport Springs, Bilstein Sport Shocks, 18" M6 Replica Wheels, 6000k HID's, Angel Eyes, Blacked out Kidneys, 20% TintComment
did your fuel cut symptoms go away too?1990 325i - Brilliantrot, 3.73 LSD, H&R Race Springs, Bilstein Sport Shocks, 4300k HIDs, Rebuilt with Metric Blue Head bolts, Planning turbo with MS by end of the year...
(wife's)
Anyone have an example diagram?
Not like an exact replica of yours but, errr, I dunno how to say it.My 2.9L Build!
Originally posted by Ernest HemingwayThere are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.Comment
re: road speed signal......
post #39 and #42.
cheers, jason
