m50 swap not firing
  • erb326
    • Jul 2009
    • 55
    m50 swap not firing
    87 325e
    W/e36 automatic m50b25 non vanos
    New swap, turn key getting the relay clicks and the cel engine
    Turn tge key more engine cranks but will not start, spark plugs are dry... no fuel
  • erb326
    • Jul 2009
    • 55
    Pump not getting power no hum when cranking the engine
    Pin #13 on the chassis side has no juice, using a multimeter
    • sweet3
      • Oct 2012
      • 752
      What ECU are you using? If it has EWS, then it wont fire
      PNP Adapter Harness Wiring for M52TU, M54, S54, M60, M62, M62TU, S62, M50, S50, M52, S52 & MORE
      • shocwav3
        • Apr 2014
        • 69
        Originally posted by erb326
        87 325e
        Is the fuel relay clicking over? If you use a jumper in place of the relay the fuel pump should fire up.
        Are you getting power to the fuel pump fuse? (fuse #11)
        Check the fuel lines, if they are backwards the pump may not start against the pressure of the regulator. (ask me how I know)
        • erb326
          • Jul 2009
          • 55
          ive had time to cool my head and gather my thoughts
          using a red label 402, which i didnt think had EWS?
          how do you make a jumper? just an insulated wire to bridge?
          dumb idea but, i took both lines off the rail cranked the engine and nothing no fuel from the lines.
          i hear nothing from the pump even when cranking, where is the relay for it?
          pin 13 (FP relay) on the body side is getting no power neither when the key is on nor when cranking
          • erb326
            • Jul 2009
            • 55
            Used the multi meter, found the fp relay on the m50 harness, put the ground pin to a chassis ground and got 0 with the key on 7.2 when cranking, checked the green and purple wire (same as in the wire harness plug)
            • e30rapidic
              • 2167
              Jump pins 30 and 87 and you should hear the fuel pump kick on. Does fuel pump out when you jump the relay pins?
              If not, check the main relay as well.
              '87 325ic, powered by S50.
              • erb326
                • Jul 2009
                • 55
                No fuel
                Pump does not sound like its coming on
                • goarmy
                  • Nov 2011
                  • 622
                  crank sensor connected in right
                  • erb326
                    • Jul 2009
                    • 55
                    As far as I can tell
                    • e30rapidic
                      • 2167
                      test for power at pump, it should come on with it jumped and ignition on. Hows the fuse?
                      • erb326
                        • Jul 2009
                        • 55
                        Jumper from 30 to 87 on the relay when cranking the pump gets no power well no sound, could hook it to the mulit meter and find out what its getting, grabbed a spare pump I had, plugged it in and it didnt kick on either.
                        Checked fuses 9, 10, 11 and 21 and all are still in tact
                        • erb326
                          • Jul 2009
                          • 55
                          These 2 wires off the diagnostic port lead go to ground right?
                          • erb326
                            • Jul 2009
                            • 55
                            So stripped back some of the shielding on the wires... one was red... hooked it to power fuel pum now operational. But it still will not kick
                            • erb326
                              • Jul 2009
                              • 55
                              Fuel is now getting all the way to the rail... but the return side of the rail is dry and the plugs are still bone dry so im thinking the fpr is not operating or am I wrong?
