OBD1 or OBD2 for s52 bottom end with a s50 top
  • Kevs87-325is
    • Jul 2014
    • 335
    Do i want to go OBD1 or OBD2. can you tell me the pros and cons, what i will need to get if i got a certain route which way is easier to get Ca Bar'd.
    Please and thank you!
  • Kevs87-325is
    • Jul 2014
    • 335
    Help
    • 2mAn
      Señior Mod
      • 21086
      OBD 2 will always be more difficult to get through the BAR. All of the emissions equipment from the donor car needs to be present. Its the main reason I went OBD1 on my swap
      Simon
      Current Cars:
      -1966 Blue Boat
      -1969 Red VW
      -1986 White BMW
      -2006 Green Thing
      Make R3V Great Again -2020
      • Kevs87-325is
        • Jul 2014
        • 335
        thanks i keep forgetting on which OBD is more difficult but i guess everyone wants OBD1 these days regardless if its s50 or s52?
        • 2mAn
          Señior Mod
          • 21086
          Yea if you want to make it legal both are possible but OBD 2 is a LOT more work. Best best is an OBD1 converted car IMO
          Simon
          Current Cars:
          -1966 Blue Boat
          -1969 Red VW
          -1986 White BMW
          -2006 Green Thing
          • golde30
            • 11464
            i think maybe 1 or 2 OBD2 swaps havae been BAR'd, but pretty sure they were buddy buddy with the ref. OBD1 seems to be the way to go.
            IG: @Baye30
            • 2mAn
              Señior Mod
              • 21086
              I want to be buddy buddy with a REF! I have some much wilder swaps I want to do
              Simon
              Current Cars:
              -1966 Blue Boat
              -1969 Red VW
              -1986 White BMW
              -2006 Green Thing
              • Kevs87-325is
                • Jul 2014
                • 335
                Thanks guys way to help me out!
                there is a car out there that has this and also he said that all it needs is an ECU to get the car Bar'd. Is the ECU an easy part or tough? I thought it would be an easier thing to do. if it hasn't been done what are the issues he might be facing because of it... like what is keeping him back from just getting it done or does it seem like there is more issues than just getting the ecu set up.
                • 2mAn
                  Señior Mod
                  • 21086
                  It just needs an OBD1 ECU? Seems sketchy. Id find one to borrow or something to make sure the car is running good before I fork over the money unless its dirt cheap. Could turn into a money pit though
                  Simon
                  Current Cars:
                  -1966 Blue Boat
                  -1969 Red VW
                  -1986 White BMW
                  -2006 Green Thing
                  • golde30
                    • 11464
                    Why would an ECU keep a car from being BARd? Unless the ECU is chipped for bolt on mods, in which case engine must be returned to stock and a new chip must be purchased for said ECU.
                    IG: @Baye30
                    • Kevs87-325is
                      • Jul 2014
                      • 335
                      see i am not to familiar with the steps here. he says it needs an ECU to be bar'd what are you thinking this is? because he hasn't said anything about being chipped which i am sure he would have said.
                      • 36brua
                        • 689
                        The ECU has to be listed on the refs computer as being used on the engine you are claiming is in the car. The S50 had a specific ECU (OBD1). it is not the same one as an S52 (OBD2). As mentioned OBD1/2 have very different smog setups. I suggest going OBD 1 for simplicity.
                        I have read that the BAR refs are/have asking for the DME specific to the S50.--1 yr. 1995 production-- Each DME has a vin # on it that can be searched for its original install.
                        They can also check the data on the block. S50 =3.0L S52=3.2L. So you're trying to BAR anS52 as an S50. GL my $.02
                        My CA legal M60 swap
                        The happening in our garage
                        • Kevs87-325is
                          • Jul 2014
                          • 335
                          Its an s50 top and s52 bottom what would you suggest since i am using both for the swap?
                          still obd1 but what about the ECU what specific one do i need or will many work on it?
