P0101 Trouble code check engine light M52 swap
  • MrGreen
    • Feb 2012
    • 130
    Hi Guys,
    I just solved my vaccum leak issue on my M50 manifold. After driving it for a couple days with out any problems I am now getting trouble code P0101. Any ideas what might be the problem?
    [IMG][/IMG]
  • DesertBMW
    • Aug 2011
    • 1040
    Maybe you got cone filter bolted directly in front of MAF, creates turbulence, MAF goes nutz
    • 328ijunkie
      • May 2007
      • 3961
      I use that same app sometimes ;) Have you verified the MAF is working at all? Does it immediately fault on key on? or does it take some driving/run time..
      Check Us out on Facebook
      Full Product Line Tuning
      • MrGreen
        • Feb 2012
        • 130
        Cone filter is direct to MAF. Should I do something else?
        [IMG][/IMG]
        Check engine light only cones on after driving it for a while.
        Last edited by MrGreen; 10-01-2014, 09:50 AM. Reason: Had a question mark after first sentence. Needed a period. :)
        • Thujalvi
          • Oct 2012
          • 72
          Yes, you should put a length of pipe between the MAF and the filter, as the turbulent air coming from the filter tends to cause incorrect readings, and a pipe, the longer the better, helps with that. Having said that, it could be that the MAF is broken, but three or four inches of 80mm/3" styainless or aluminium pipe is probably going to be cheaper, and is something you'd want there anyway.
          '93 Daytonaviolett Touring Design Edition
          • MrGreen
            • Feb 2012
            • 130
            I'll add the 3-4" of pipe to the front and keep you guys posted. Thanks!
            • MrGreen
              • Feb 2012
              • 130
              Was getting a little bit of a rough idle. I figured I'd pull off the MAF plug (for the sensor). The engine immediately died.
              Checked the codes and I got the P0101 as I did before and this one (P0121):
              [IMG][/IMG]
              I cleared the codes and restarted. It starts up at 2500RPMS and then dies down a bit and keeps swinging between 1400-1800RPMS.
              If I gas it, it will not go above 2500RPMS. If I put it in gear, and give it gas, it dies.
              • MrGreen
                • Feb 2012
                • 130
                O ya and it smells really rich right now
                • 328ijunkie
                  • May 2007
                  • 3961
                  You unplugged the MAF and got a TPS code? Thats new. Give us a shout and lets make sure its not an issue on our end (although ive not heard of this to this point lol)
                  • 328ijunkie
                    • May 2007
                    • 3961
                    Will it run with the MAF disconnected? It should run/drive fine for the most part sans some weird throttle response...
                    • MrGreen
                      • Feb 2012
                      • 130
                      Just called and texted
                      • MrGreen
                        • Feb 2012
                        • 130
                        Runs high RPMs with and without MAF now
                        • 2mAn
                          SeƱior Mod
                          • 20990
                          ahh crap...
                          Simon
                          Current Cars:
                          -1966 Blue Boat
                          -1969 Red VW
                          -1986 White BMW
                          -2006 Green Thing
                          Make R3V Great Again -2020
                          • MrGreen
                            • Feb 2012
                            • 130
                            Originally posted by 2mAn
                            ahh crap...
                            It happened about an hour after I hung with ya. Lame...
                            At least it's Friday :)
                            • MrGreen
                              • Feb 2012
                              • 130
                              Ok, so the bad news is that I had a shop test the MAF and TPS by swapping out working ones they had. Issue of really high idle is not going away, so apparently both work on my car. Any idea what it could be?
                              I can use my ELM327 and OBD Fusion app and the BMW shop can use their generic code reader. We both get the same codes. But, they can't use their other code reader to check any deeper the BMW trouble codes to see what's specifically wrong. My DME won't tell them anything. Is it possible the DME is messed up?
