P0101 Trouble code check engine light M52 swap
  • MrGreen
    • Feb 2012
    • 130
    Good news. Turns out there was a glitch in my ECU Flash. Markert got me all fixed up on the weird throttle issue. It's been running great the last couple days, but I am getting another CEL. The two codes are p1189 and P0173. Do I have an exhaust leak somewhere? Any idea where?
    [IMG][/IMG]
    • 328ijunkie
      • May 2007
      • 3961
      I think both of those are bank two... Look there. Icv in the manifold all the way?
      Check Us out on Facebook
      Full Product Line Tuning
      • MrGreen
        • Feb 2012
        • 130
        As far as I know ICV is in the M50 manifold all the way. I'll check again and check bank two exhaust to make sure it's bolted down all the way. Thanks!
        • MrGreen
          • Feb 2012
          • 130
          Side note: when the code reader says that there are pending codes, what does that mean?
          • MrGreen
            • Feb 2012
            • 130
            Need some more direction here:
            I took the car in for a smoke test and too my surprise, the manifold was not leaking. However the valve cover was and it was pouring out smoke from coil six area. The shop told me I had a cracked valve cover. I just replaced the valve cover and gasket and am still getting the same 3 codes: P0170, P0173, and P1189. I also checked the old valve cover for cracks and cannot find even the slightest crack. Is there anything I am missing. I am assing I am still leaking from there with the new valve cover. What would cause the valve cover to leak so bad?
            • 2mAn
              SeƱior Mod
              • 20669
              try smoke-testing it again
              Simon
              Current Cars:
              -1966 Lotus Elan
              -1986 German Car
              -2006 Volkswagen Jetta TDI
              Make R3V Great Again -2020
              • MrGreen
                • Feb 2012
                • 130
                Just heard the results of the smoke test. The valve cover is pretty well sealed. Very light leaks that the mechanics said would likely not cause a problem. So, it looks like its sealed and without vacuum leaks. They said they tested one bank's O2 and it is lean and the other is rich. Said one O2 had the heat shield burnt off, but the 4 wires are all intact (which I had seen earlier), but that it was reading only 4volts. They want to look at it more on Monday, but should I just save the expense and pick up a couple new O2s and see if that fixes it? Almost everything else is new. The O2s were used so I could see if they are a problem.
                • 328ijunkie
                  • May 2007
                  • 3961
                  What are your actual fuel trim #s?
                  • MrGreen
                    • Feb 2012
                    • 130
                    Great news! It was a faulty O2 sensor in bank 2. Now that it is replaced no more codes or CEL. I drove 85 miles yesterday with multiple starts and stops and nothing. Super pumped. Now I have to schedule my bar apt :)
                    • MrGreen
                      • Feb 2012
                      • 130
                      Thanks for all your help men!
                      • 328ijunkie
                        • May 2007
                        • 3961
                        woot!
