Double check my wiring harness adapter before I solder it tomorrow please?
  • brshelton
    • May 2014
    • 102
    Im fairly certain this is correct but never hurts to ask. 12/29/86 production 325i going to obd1 m52.
  • f4tj0n
    • May 2013
    • 411
    I'm pretty sure most people are going to tell you not to solder it.
    • brshelton
      • May 2014
      • 102
      How come? Having a friend who solders as part of his day job doing HVAC solder it with his fancy setup. What is the down side to soldering? I'm unfamiliar really.
      • delamaize
        • Nov 2013
        • 1465
        If you know how to solder properly, and you plan on shrink wrapping all the joints, I'd do it. It'll be a long lasting reliable connection.
        Dumpster Fire Pilot
        • 328ijunkie
          • May 2007
          • 3961
          Soldering was never meant for automotive applications... Look through your car and find a "factory" solder point... Only one youll find is on a circuit board or to supplement a crimp. HVAC and and some industrial applications can use it very reliably because of lack of extreme climate change, vibrations, etc.
          Check Us out on Facebook
          Full Product Line Tuning
          • Coupelx
            • Oct 2013
            • 169
            Ive soldered loads of wires on stuff over the last 10 years. Even built a few wiring harnesses.
            • M3PO
              • May 2012
              • 537
              Soldering makes wires brittle. Solder connections can break with time in vehicle applications due to vibration.
              • brshelton
                • May 2014
                • 102
                Good to know. Well did anyone double check my wiring by chance? lol
                • mcdougal
                  • Nov 2014
                  • 251
                  Did you ever get this sorted? My wiring diagram (86 eta to obd1 s52) looks almost identical which gives me hope that I'm headed in the right direction.
