I have the S52 rotating assembly and a M52 block. I dropped off the block at the machine shop to get cleaned and checked if its good im going to have it bored out to s52 specs. The question I have is what rings should I be using and what should the clearance be?
S52 build with M52 block
Originally posted by FerdinandI carry a cheap pressure gauge in my glovebox with which to manually check my tire pressures, but I keep forgetting that in the USA glovebox space is sacred as it is reserved exclusively for the purpose of storing handguns.
DIVING BOARD DIVISION DIVISION IDIOTTags: None -
The block is the same but the bore is different. M52 has 84mm bore S52 has 86.5mm boreOriginally posted by FerdinandI carry a cheap pressure gauge in my glovebox with which to manually check my tire pressures, but I keep forgetting that in the USA glovebox space is sacred as it is reserved exclusively for the purpose of storing handguns.
DIVING BOARD DIVISION DIVISION IDIOTComment
what clearance are you wondering about? Rings would be spec'd to whatever piston you are using since the M52 block will have to be bored out to fit the S52 pistonsSimon
Current Cars:
-1966 Blue Boat
-1969 Red VW
-1986 White BMW
-2006 Green Thing
Make R3V Great Again -2020Comment
Ive never had a motor fully rebuilt so im a bit lost, please bear with me. The machinist said he needed the clearance between the piston and the block. Should he be able to determine that with just the pistons and rings?Originally posted by FerdinandI carry a cheap pressure gauge in my glovebox with which to manually check my tire pressures, but I keep forgetting that in the USA glovebox space is sacred as it is reserved exclusively for the purpose of storing handguns.
I would just bore it to the stock s52 bore size. I believe that is 86.4mm. That should allow the stock piston rings to work like normal.
efficient, the heads are actually identical. The only differences are the springs, spring washers, and cams.Last edited by sweet3; 02-03-2015, 11:44 AM.Comment
I suggest you do some reading through the BMW TIS for e36 M3. You can view it online, though it's in Russian. Chrome translates for me... your machinist is referring to the piston to wall clearance. That data is in the TIS, you want to look at the "repair manual" for the e36m3 for all of the measurements. It contains ALL of the data to rebuild a BMW motor to BMW spec, here is the s52 page: HERE
If you read through the documents, you will see several dimensions which should help you understand the correct bore size.
Piston size: 86.365mm
Piston to bore gap: 0.026 - 0.058mm
This would give you a tolerable bore size of 86.391mm to 86.423mm
Or you can also see that the bore size is stated to be 86.400mm (which gives you a piston to cylinder wall gap of .035mm which is on the lower side of the tolerable range, aka perfect)
I am also doing an s52 rebuild/swap and boring out an m52 block to 86.400mm
You need to read read reeaaaddddddd
EDIT: I don't know what your goals are, but I would replace everything if you are rebuilding. rod bearings, main bearings, piston rings, every gasket, every o ring, you need new main and rod bolts (they are stretch bolts - one time use). It is not a cheap nor easy endeavor, but well worth it imo when it is finished.Comment
Thank you verry much. My goals are to replace everything. Id like to have a 0 mile lower end to replace my current junkyard built 2.8 lower end.
I know what you mean with it not being a cheap endevor. Even the junkyard build was pricyOriginally posted by FerdinandI carry a cheap pressure gauge in my glovebox with which to manually check my tire pressures, but I keep forgetting that in the USA glovebox space is sacred as it is reserved exclusively for the purpose of storing handguns.
No problem. Sounds like we are both working on the same project. I have been researching this heavily for the last several months, buying parts reading etc. Finally ready to build, getting my block back from the shop in a day or so. I wanted a brand new bottom end and no leak motor for daily/autox duty. Honestly though, without going crazy, I think it can be done for around 1k.Comment
When we do a full rebuild, the machine work for the bottom end alone will exceed $1k. This is a bore/hone, deck, aline bore mains, weight match rotating parts, polish crank, re-bush/resize rods, and balance rotating assembly.Comment
