Run out of options on this no start situation (solved)
1988 Atlantisblau Euro/Japanese 325i Cabrio
1989 Schwartz 325i - now M50 powered! - now very dead
1998 Toyota 4Runner Limited - gone
My 17,000km Big NA National Parks trip! -
I had this happen with my m50 swap. Check the wiring to the fuel and the dme to make sure that is correct. I believe we had a wire that was not connected or it was backwards. It fired right up after we fixed that issue.Comment
I'm using Nando's adapter, so i'm pretty positive it's all done correctly - if all else fails i'll take it apart and double check i guess, but i'd rather try everything else first.
-No fuel getting injected (plugs are dry, and no smell)
-No spark still
threw another engine ground in and that didn't make a difference
-Checked the injector ground and directly grounded it to the strut tower. made no difference.
-Swapped FP relays, no difference
-replaced a burnt fuse - no difference
@GDA, exhaust ports are dry1988 Atlantisblau Euro/Japanese 325i Cabrio
My 17,000km Big NA National Parks trip!Comment
maybe I missed it before if it was already addressed, is everything getting power from a main power dist block? or have you retained the e30 original power block with a "main" large cable and a "smaller" separate cable?
if the power is coming from the original e30 block with separate blocks and large + small cables, check the fusible link in the trunk shortly after battery. This sounds very similar to a no start I had
if this info has been covered, my apologies - I skimmed the threadComment
I used the original fusebox and starter wiring from the e30. I removed the starter wire (2 ends that become 1 at the power block).maybe I missed it before if it was already addressed, is everything getting power from a main power dist block? or have you retained the e30 original power block with a "main" large cable and a "smaller" separate cable?
Fusible link looks good too.
Swapped the relays around just in case too, no dice.
EDIT: also found 1200ohms at the x6000 connector for the CPS so i know that's goodLast edited by Sea Aych; 05-09-2015, 12:59 PM.1988 Atlantisblau Euro/Japanese 325i Cabrio
a-ok
Summary:
-CPS is good, reads correctly at DME x6000 connector too
-No Spark
-No Fuel injection
-Can smell fuel in bay after cranking
-Fuel pump won't prime
-Have power to fuel pump relay, still no start after swapping relays
-Can jump the fuel pump at the relay by bridging the pins (pump works and has power)
-all fuel-related fuses OK
-Fusible link OK
-C101 wiring done by nando's adapter
-engine grounds OK (added another just in case the first had gone bad, even though it looked good. no dice)
-i'm using original e30 starter and fusebox wiring (took the m50 ones out of the harness)
-main relay clicks on
-windows and blower don't work unless i jump the pins on the unloader relay (suspect it's a bad starter ground, but they still don't work when i ground the 30h wire directly)1988 Atlantisblau Euro/Japanese 325i Cabrio
How is the E36 motor harness getting power if you have not connected the E36 harness power cable into the E30 fusebox?a-ok
Summary:
-No Spark
-No Fuel injection
-Fusible link OK
-windows and blower don't work unless i jump the pins on the unloader relay (suspect it's a bad starter ground, but they still don't work when i ground the 30h wire directly)Comment
mis-spoke, sorry - the power to the harness is still attached at the distribution block on the passenger side. harness has power
As well, i'm getting a power to fuse 11, but the pump won't prime, and doesn't sounds like it's on during cranking..
I think the residual fuel in the lines is from me testing the pump by jumping the relay.
I also tested almost 12 volts at quite a few DME pins at the x6000 connector1988 Atlantisblau Euro/Japanese 325i Cabrio
The two wires leaving the top of the distribution block are the e30 starter wire and the e30 fusebox wires (two turn into one).
This now is the second ground i added on the passenger side from the screw on the e36 mount arm to the body, just because i figured even though the driver's side regular ground looked fine, it may have not been. Made no difference
I can't tell from the pictures if there is anything connected to the fusible link power terminal at the distribution block (if you already verified it gets power, than ignore me) but just fyi mine appeared to be fine visually, but was actually bad. 3 days later I eventually chased it down with a multimeter.
Regardless, good perseverance. You'll figure it out.Comment
What do you mean connected to the fusible link power terminal? The small wire coming out of the left of the picture with the fat one is the one with the fusible link in the trunk. The wire from the harness should go there instead (it's currently attached to the underside of the distro block there, on the right side of it.).I can't tell from the pictures if there is anything connected to the fusible link power terminal at the distribution block (if you already verified it gets power, than ignore me) but just fyi mine appeared to be fine visually, but was actually bad. 3 days later I eventually chased it down with a multimeter.
Regardless, good perseverance. You'll figure it out.1988 Atlantisblau Euro/Japanese 325i Cabrio
I was asking if anything was attached to the "small wire" but it sounds like you have everything attached to the large power wire/terminal. Never mind.What do you mean connected to the fusible link power terminal? The small wire coming out of the left of the picture with the fat one is the one with the fusible link in the trunk. The wire from the harness should go there instead (it's currently attached to the underside of the distro block there, on the right side of it.).
Carry on.Comment
