S52 valve spring seats
  • acolella76
    • 2950
    Hi guys, on the final leg of getting my motor together and I hit a snag. Apparently the lower valve spring seats are different between an M52 and S52 (the S52 being thicker supposedly). The ones I have are for an M52.
    Number 6 in this diagram
    Could someone tell me the thickness of the S52 spring seats so I know what I'm looking for? I thought about buying new, but they are $8/ea... so I would definitely rather dig through old parts bins than buy new. Or if you have a set that you want to sell me, even better!
    -Alex
  • 328ijunkie
    • May 2007
    • 3961
    The S52 ones are def thicker... We prob have some laying around.
    Check Us out on Facebook
    Full Product Line Tuning
    • 328ijunkie
      • May 2007
      • 3961
      Some argue S52 springs are same as M52 just with thicker base shim...
      • Northern
        I like cupcakes & sh!tboxes
        • 5284
        That wouldn't be too hard for someone to test, or have tested.
        Originally posted by priapism
        Originally posted by shameson
        • acolella76
          • 2950
          I bought new S52 springs and the wire diameter is about 0.1 mm smaller than the M52 springs I have. Same height, but they're different. Do you know what the thickness is? I could maybe just buy shims to make up the difference.
          Let me know if you have some! I still need a lot of parts as well that I could pick up all at once
          -Alex
          • 328ijunkie
            • May 2007
            • 3961
            We have some if you care to sift through the massive bin of shims/springs we have.
