What swap setup are you doing? M52/S52 obd2? Also, will you be using an E36/Z3/etc harness? What year/model is your e30?
Are you planning on having our harness modified? Or get an adapter?
The harness modification includes changing the engine harness connector to plug directly on your fusebox. The round diagnostics port is also adjusted to be able to fit into the standard location on the firewall covers.
Although the round diagnostic port can be used, a standard OBD2 port can be installed as a special request. If your e30 chassis does not have a CEL, let us know and we can install one that can be used.
