PNP Adapter Harness Wiring for M50, M52, S50, & S52 (And MORE!)
  • UgkNW*
    • Oct 2013
    • 259
    #76
    Yo can i cut the sap and rear o2s out of my harness and just heat shrink them and be good to go? Figuered you'd know thanks
    • sweet3
      • Oct 2012
      • 752
      #77
      Yes you can do that. Tuning them out of the DME is not required, but I would suggest having them properly removed from the DME as well. Before you cut anything out of the harness, make sure your car fires up and runs. Those are easily accessible once the engine is completely installed. And of course, disconnect the battery when you do the modifications :)
      PNP Adapter Harness Wiring for M52TU, M54, S54, M60, M62, M62TU, S62, M50, S50, M52, S52 & MORE
      • sweet3
        • Oct 2012
        • 752
        #78
        Our M54 EWS deletes are now included with our adapters at no extra cost.
        Others will be out soon!
        • sweet3
          • Oct 2012
          • 752
          #79
          Bump
          • sweet3
            • Oct 2012
            • 752
            #80
            bump
            • sweet3
              • Oct 2012
              • 752
              #81
              Bump
              • eThirtyAaron
                • Sep 2015
                • 144
                #82
                This is so cool man. Props to you. Not sure on M52 or S50 yet, but I'll be hitting you up either way.
                • sweet3
                  • Oct 2012
                  • 752
                  #83
                  Excellent, let me know whenever you're ready 👍
                  • noypi2
                    • Jun 2014
                    • 442
                    #84
                    I'm on the process of collecting parts for a S52 swap on my M10 E30. IS there a specific harness for the M10 motor? M10 dont have CEL but i want to put one for BAR inspection. Also going OBD1.
                    • sweet3
                      • Oct 2012
                      • 752
                      #85
                      Yes I can get one made for your setup. I can make you an adapter with the CEL on it for you. You can just run the light to your cluster.
                      You will just need to find either as S50 engine harness or a 93-95 e36 m50 engine harness if your going OBD1. You can also use an e34 m50 engine harness.
                      • sweet3
                        • Oct 2012
                        • 752
                        #86
                        Bump
                        • Sladek
                          • May 2016
                          • 228
                          #87
                          ive got an s52 thats converted to OBD1 in an 89 M3, looking for an adapter to go with that and would include wiring for a CEL (since the M3s didnt come with one). i assume it would be PNP if i found an S50 harness?
                          • sweet3
                            • Oct 2012
                            • 752
                            #88
                            Excellent, I can get one made for you with the CEL wiring. You can use any S50 harness. Or you can use an m50 harness from a 93-95 e36.
                            • Sladek
                              • May 2016
                              • 228
                              #89
                              and if for whatever reason i change it to obd2 i just cover shipping both ways? would obd2 include a diagnostic port or would that be on the engine side?
                              • Dagamus(NM)
                                • 621
                                #90
                                What about for s52?
                                Gun control means using both hands
                                Sex, Drugs, Rock 'n roll. Pick two.
