Clutch line issue help!
  • helghit
    • Jun 2015
    • 29
    Hey guys, I began to finish swapping my euro car and ran into a problem with the clutch line that goes directly into the slave cylinder. It seems as if it was just so old and rusted that the metal line just broke, I've looked everywhere but cant find a line that has the that metal line going into the braided line with the same fittings. If anyone can help me get a part number or suggestion it would help alot since I'm on a big deadline, Thanks!
    Here are some pictures
  • Fsnow
    • May 2015
    • 184
    There are many options for this line. Oem style ( I recommend blunttech) or stainless steel braided options from Catuned, rogue, uuc etc. Should be easy to find one.
    1991 318is x 2 .
    • Old city bimmer
      • Jun 2014
      • 1114
      Check Oreily auto parts if you have one local.
      Sent from my iPad using Tapatalk
      323i MTEC1
      Z3 coupe
      E60 M5
      • Fsnow
        • May 2015
        • 184
        Yeah local would be quicker but I have stopped relying on my local stores due to high prices, inferior quality, if they even have it at all. Hopefully it's better where you're at. I'm just used to ordering everything from the u.s. and waiting a few days.
        If you ever need any part #s use realoem, or even Google sometimes.
        1991 318is x 2 .
        • Old city bimmer
          • Jun 2014
          • 1114
          I got a Euro...so the Internet for me.
          323i MTEC1
          Z3 coupe
          E60 M5
          • Northern
            I like cupcakes & sh!tboxes
            • 5277
            should be the same as any US spec car.
            ^ should work fine, or similar.
            Originally posted by priapism
            Originally posted by shameson
            • M3PO
              • May 2012
              • 537
              I use the IE line with my ZF trans
              • f4tj0n
                • May 2013
                • 411
                piggybacking on this thread:
                Whats the easiest way to install a slave onto a ZF with it in the car? Looks like I'm going to have to either pick the motor up with a cherry picker, or drop the subframe.. cant get it in there!!
                • M3PO
                  • May 2012
                  • 537
                  I was able to replace it just fine.
                  • f4tj0n
                    • May 2013
                    • 411
                    you were able to wedge the slave between the transmission tunnel and the transmission? there is no way in hell I fan get it in there..
                    • justin_l_
                      • Jun 2007
                      • 1079
                      I didn't find it hard, use an extension to get at the hardware.
                      • M3PO
                        • May 2012
                        • 537
                        Correct, I didn't find it that hard at all. Sounds like something is weird with the position of your trans.
