OBD2 Manifolds on OBD1 Exhaust System
  • KI4UJO
    • Jun 2011
    • 642
    Since my car originally was m50 swapped, I used the OBD1 cast manifolds. After buying an m52 (m50 had a cracked block), I decided that I would like to use the OBD2 shorty headers. However, I was wondering if anyone knew if they would bolt right up to my existing exhaust, as it is built for the cast manifolds? It's a lot easier to know in advance then to have to change them in the car.
    thanks in advance
    IMG_0145 by Jonathan Martin, on Flickr
  • tytypetersen
    • Mar 2012
    • 347
    Yup they'll bolt right up!
    • e304lyfe
      • 807
      not necessarily true. if your obd1 cast manifolds came from an e34 then your exhaust will not fit without modification.
      • 2mAn
        Señior Mod
        • 21006
        That's what I have on mine . I have to put the OBD1exhaust manifoldson my car when I go to the BAR so I'll be dealing with swapping them soon.
        The last time I looked, Real OEM actually shows the same part # for the E36 & E34 manifolds.
        Simon
        Current Cars:
        -1966 Blue Boat
        -1969 Red VW
        -1986 White BMW
        -2006 Green Thing
        Make R3V Great Again -2020
        • e304lyfe
          • 807
          e36 and e34 rear manifold is the same (11621716733), but front have different part numbers.
          e34: 11621716730
          e36: 11621716736
          • 2mAn
            Señior Mod
            • 21006
            Thanks for clearing that up
            Simon
            Current Cars:
            -1966 Blue Boat
            -1969 Red VW
            -1986 White BMW
            -2006 Green Thing
