Which Driveshaft for s50 swap? Also, which aftermarket shifter are you using?
  • damastah
    • Mar 2014
    • 92
    Hello guys,
    I have an s50 and zf trans out of a 95 m3.
    People are saying that I need 328i automatic e36 driveshaft, others are saying i need a 96+ manual driveshaft.
    Who has done the same swap I have done and what driveshaft are you using? Was it a perfect fit?
    My trans also doesn't have a shifter on it. I was thinking about buying an entire aftermarket shifter kit, or taking a shifter off of a 1.9 z3. Not sure yet. What aftermarket shifter kits are you using and how do you like it?
    Thanks,
    Josh
  • FredK
    • 14763
    Manual E36 328i driveshaft
    Manual E36 M3 FOUR BOLT driveshaft
    E30 M3 driveshaft
    Auto 328i does not work.
    • damastah
      • Mar 2014
      • 92
      Okay cool. Thanks.
      I was thinking about a 96-98 328i manual one. I think that's the one I'm going to get.
      • ForcedFirebird
        • Feb 2007
        • 8300
        E30 M3 driveshaft
        Late eta manual drive shaft with the large giubo also works. Also not the e36 shafts need the CSB to be installed backwards.
        john@m20guru.com
        Links:
        • NotJesus
          • Mar 2015
          • 169
          Also running an s50/zf from a 95 car, I decided to go with the r3vshift adapter guibo, to adapt the 'small flange' on the e30 driveshaft (87 25is') to the 'large flange' on the zf trans. Was around 130- but I ended up having to grind a few mm on a few areas of the zf output flange to clear the bolts on the adapter guibo.
          Thread regarding the r3vshift guibo - http://www.r3vlimited.com/board/showthread.php?t=243268
          The driveshaft must come from a car with the same size flange as the ZF units - 96mm (the e30 has a 78mm flange), and must have a 4 bolt main flange on the differential flange side, to match up with the e30 diff which uses a 4 bolt flange.
          E30 M3 driveshaft
          For the shifter linkage, I used the g260 carrier and linkage, and the e36 selector rod. The Zf has a different selector rod holder on the trans side, which requires the use of the e36 ssr, something you would have to change if you were to get a dssr.
          If you need to buy an entire new linkage setup, I would recomend going with something along the lines of UUC evo3, and a matching dssr. Get the appropriate hardware to match your trans- ie all 95' m3 stuff. Youd be shocked by the difference between stock and a dssr/ short shift kit. Shifting feels so much better its crazy.
          Good luck with finishing up
          • agent
            Vice Grand Pubaa
            • 7960
            I'd strongly recommend the correct driveshaft Fred noted above over this method.
            Originally posted by kronus
            • f4tj0n
              • May 2013
              • 411
              Do you say this because of a bad experience with the product?
              • ForcedFirebird
                • Feb 2007
                • 8300
                I have. So has this guy...
                john@m20guru.com
                Links:
                • zcenterb
                  • Feb 2014
                  • 2105
                  From an engineering standpoint its much smarter to have the larger driveshaft for the more powerful engine anyway, I don't know why you would go with the r3vshift adapter when you can find a used driveshaft that is compatable for roughly the same cost... you would be just introducing more stress to the system. I have no experience with the r3vshift piece however, just adding my engineering .02.
                  OP, I used stock e36 shift linkage in my s50/zf setup and it works perfectly. Also using AKG engine and trans mounts for what its worth. good luck.
                  CENTERBAR MOTORSPORT - Check out my small Bimmer/Beamer parts and custom projects business!
                  Instagram: @centerbarmotorsport
                  Facebook: https://www.facebook.com/centerbarmo...?ref=bookmarks
                  The Fleet:
                  -1984 325ei Lapis
                  -1991 325ix Diamond
                  - 2005 X5 4.4i Black Sapphire
                  -1972 2002tii Fjord - SOLD 7/8/17
                  -1991 325i S50 ///Sterling Silver/// - SOLD 9/15/17
                  The Bike:
                  -1980 R100RS Inca
