Guide to your OBD2 swap! Diagnostics and logging
  • Mwishlist
    • Jul 2013
    • 505
    I have the ODBII port, so I bought the Wifi adapter you linked too.
    Thank god, R3V was getting boring since the ginger kid wrecked his car. - Stonea
    • BlackSpeed66
      • Apr 2008
      • 624
      Originally posted by 328ijunkie
      Stock MAF? O2 sensors plugged in correctly as far as Bank 1/2? Whos tune?
      1. Yep stock MAF that came w/ the engine. No MAF codes pulled that I'm aware of.
      2. O2 sensors should be on properly - I triple checked all connections before i fired it up for the first time. No O2 sensor codes I'm aware of. That said, I will check the wiring again this weekend as the car was at the exhaust shop for 2 months - they should have only had to touch one of the manifolds but stranger things have happened, right?
      3. Yours ;)
      -Geno
      '87 325is (s52'd)
      '95 525iT
      '95 Jaguar XJR-6
      '02 Range Rover 4.6 HSE
      '98 Disco 1
      • 328ijunkie
        • May 2007
        • 3961
        1:MAF being wrong/broken usually causes Fuel trim issues, MAF rarely codes.
        2:I mean bank 1 plugged into bank 1 plug and vise versa. Theyre the oppsoite of what you think. Bank 1 plugs into the rear plug and bank 2 plugs into the front plug
        3:Last 7 of VIN on ECU?
        Check Us out on Facebook
        Full Product Line Tuning
        • BlackSpeed66
          • Apr 2008
          • 624
          VIN on the ECU is EY74524.
          I will look into the MAF issue and inspect it more closely to see if there's anything out of order there. I know the O2 sensors are goofy with the location of the connectors in relation to the sensors themselves (after reading many threads on the issue here!) - so I made sure they were connected in proper fashion. Still will double check though since the car was at the shop for two months...
          Working on finding something Windows based so i can get these logs off my phone at some point....
          -Geno
          '87 325is (s52'd)
          '95 525iT
          '95 Jaguar XJR-6
          '98 Disco 1
          • Mwishlist
            • Jul 2013
            • 505
            Thanks for this thread. I got the wifi reader up and running with ODB Fusion, best $30 I've spent so far on this swap. Couple of questions:
            1. My temp readings on ODB Fusion shows 240 regardless of what the actual temp gauge in my cluster shows. Car seems to be running at the right temp but I also get a P0116 Engine Coolant Temp Circuit Range Performance code. Not sure if this is normal for a swap with the M20 Temp sensor of if the ECU is not communicating the right temp?
            2. I have a P0340 CPS circuit error as well, which is triggering my CEL. I think the CPS is actually going bad though. I checked the wiring etc. and I have a new one on the way.
            3. The tach on ODB Fusion reads about 300 - 500 RPM higher than the tach in my cluster. I'm S52 swapped with an 8k tach overlay and the M5 coding plug in my cluster. I think my cluster is correct because according to it, the idle is solid at 600 RPM when idling. Not sure how to see which is right?
            Note: My ECU has been previously water logged and I only recently got the Tach working by resoldering some connections. Dave, I'll be sending you a fresh non-water damaged ECU for you to tune on Monday.
            • NC325iC
              • Mar 2004
              • 6565
              You have an OBD2 port wired or are you using the 20 pin? The 20 pin setup may require having the switched power run to it though i dont know why. (pin 6 C101 usually)
              I have the diag adapter and a Bluetooth reader. Doesn't seem to get power. Any more details on what wire needs power?
              Sent from my Nexus 5X using Tapatalk
              • grinchxvx
                • Dec 2015
                • 295
                What's used to data log on turbo setups? Does RK or trm send you a logging device?
                • Northern
                  I like cupcakes & sh!tboxes
                  • 5283
                  romraider logger works decently for turbo logs other than boost/wideband AFR. It will log it, I just don't know how to hook it all up so RRlogger will read it.
                  megalogviewer works pretty well for reading. Took me a while to think to even try.
                  Originally posted by priapism
                  Originally posted by shameson
                  • 328ijunkie
                    • May 2007
                    • 3961
                    Shoot us an email to tuning@markertmotorworks.com And we can see if we can be of any assistance :) Looks like we did your ECU back in June.
                    • Sh3rpak!ng
                      • Jan 2014
                      • 2667
                      Great thread!! Just saw this. I'll be checking back in a few months after the e30's accident is repaired. Very interested in this stuff for both the obd2 e30 s52, and my e36 m52.
                      And yes dave I still plan on going with your tune after the e30 is back on the road!!!! :D
                      Shadetree30
                      • BlackSpeed66
                        • Apr 2008
                        • 624
                        Thanks Dave - let me try a few more things here before i get you guys on the horn. It appears winter has finally hit Cleveland here so the car's not going anywhere for a bit
                        -Geno
                        '87 325is (s52'd)
                        '95 525iT
                        '95 Jaguar XJR-6
                        '98 Disco 1
                        • NC325iC
                          • Mar 2004
                          • 6565
                          Any more on what pin needs power?
                          • 328ijunkie
                            • May 2007
                            • 3961
                            gn/white at diag port needs power.
                            red a diag port needs power.
                            • NC325iC
                              • Mar 2004
                              • 6565
                              Both get +12? Any pin numbers?
                              • 328ijunkie
                                • May 2007
                                • 3961
                                www.wedophones.com/BMWManualsLead.htm ;)
