M52 aluminium blocks
  • pazi88
    • Sep 2015
    • 584
    Hi! I made short video about two types of m52 aluminium blocks. I don't know if this useful information in US, but other countries should have also these alu blocks. It's in finnish, but I added english subtitles.
    There is also lot of rumors that these alu blocks cant handle boost. I must disagree because I have ran m turbo with alu block for a while now and I have had zero problems caused by that. I have been running up to 20 psi of boost and no problems even with stock head bolts. Only change I have made is Athena cooperring headgasket.
  • 328ijunkie
    • May 2007
    • 3961
    Great video. I was under the impression all the US ones were sleeved.
    Check Us out on Facebook
    Full Product Line Tuning
    • Wishno87
      • 6025
      That is pretty neat. Turns out mine has iron sleeves.
      • Tippey764
        • Aug 2014
        • 108
        In the US the only m52 aluminum blocks came in 97-98 Z3 2.8's.
        • 2mAn
          Señior Mod
          • 21017
          I approve of this thread
          Simon
          Current Cars:
          -1966 Blue Boat
          -1969 Red VW
          -1986 White BMW
          -2006 Green Thing
          Make R3V Great Again -2020
          • megatron
            • Jul 2014
            • 152
            Great vid. All the US M52 alloy blocks I've worked with were sleeved. They are also a pain in the butt to find due to what Tippey764 said.
            GearSwitch E30 Cup Holder available now at http://gearswitch.us
            • pazi88
              • Sep 2015
              • 584
              Ok that's good to know. I will add the information to video description. I already know that most of the M52 blocks in US are cast iron, which is basically the the same as in M50.
              • Loupoz
                • Feb 2012
                • 166
                This is awesome information! I was under the impression all M52's were with nikasil lining.
                My 325I Mtech1 S54 Build
                • Hooffenstein HD
                  • Nov 2012
                  • 1388
                  Good information. Thanks for taking the time to make the video and put English subs on it.
                  • pazi88
                    • Sep 2015
                    • 584
                    And here is another video about these aluminium m52 blocks. As you may know these are famous from head bolt threads that will strip out easily. I haven't stripped out any threads yet, but I'm aiming for more boost next summer. So just in case I decided to time-sert the new block that I'm going to install. Of course the same procedure works if you have already stripped the threads. The real m52 time-sert kit is crazy expensive (300-500 usd), so here is video how you can do the time-serting with cheaper universal kit:
                    I also added English subtitles to this video.
                    • mr2peak
                      • 2388
                      Helpful, thanks
                      Drive it hard. Maintain it well.
                      A Topless Memorandum
                      • King Mufasa
                        • Sep 2012
                        • 530
                        are you sure?? i was told the e39 single vanos m52 also came in aluminum...
                        • mr2peak
                          • 2388
                          Pretty sure the Z3 was the only aluminum block in the USA. E39 single vanos was aluminum in the rest of the world.
                          Do the aluminum blocks have the same crank as the early iron blocks?
                          • pazi88
                            • Sep 2015
                            • 584
                            No. The late models have the crank sensor at the Back of the engine. These have same crank as in m52tu.
                            EDIT oh! there was topic about this already.
                            • mr2peak
                              • 2388
                              So both Aluminum blocks have the later TU style crank?
