s50 regrind camshafts
  • acolella76
    • 2950
    Originally posted by 328ijunkie
    The stock lifters DO NOT take up the slack necessary to use a reground cam. semi colon.
    Depends. On Pasha's regrinds which were Riot Racing, his lifters were maxing out so you are right there. However I have regrinds from BimmerHeads and the lifters are not even close to maxing out. It seems Riot Racing just takes way too much off the base circle. I was dumb and didn't measure before sending my cams out so I don't know how much BimmerHeads took off.
    -Alex
    • 328ijunkie
      • May 2007
      • 3961
      Wasn't aware they did regrinds so yes I was talking directly about RRs though I've seen others with similar base circle cuts that don't work.
      Check Us out on Facebook
      Full Product Line Tuning
      • Northern
        I like cupcakes & sh!tboxes
        • 5284
        when I asked bimmerheads about M5x regrinds, I received no response, so I assumed they didn't do them.
        Originally posted by priapism
        Originally posted by shameson
        • dadsbmw
          • Oct 2014
          • 475
          Pulling this up from the dead. I rarely see anyone talk about Riot Racing reground cams these days, but found a set for sale locally. Since my s52 cams are currently out I figured it would be an easy upgrade. Seeing a prolific tuner claim that the HLAs can adjust for the material removed from the base circle is obviously concerning!
          Thoughts?
          2003 Z4 3.0 6-speed- Silver, 19's, daily driver
          1990 Silver 325i- Lowered on H&R OE Sports, e90 drop hats, KYB shocks, color matched rocker panels, 16" Emortal RS wheels on 205/50/16 tires... Currently getting a full refresh including an S52 swap!
          1997 Black Ford Probe GT- Stripped to 2220lbs, MS3X, Forged motor in midst of assembly... Dyno results and 1/4 mile times pending
          • pazi88
            • Sep 2015
            • 584
            Thoughts?
            If the regrind has been done correctly, the lifters can compensate base circle change easily. But the amount of base circle that can be removed is not much. About 1mm. So if the reground cams are advertised to have something like 11mm or more, lift, it's too much and you need to grind the oil feed holes in lifter trays at least.
            • gazellebeigem3
              • Jun 2005
              • 3712
              I've been told by a couple reputable cam dudes that these cams don't take well to regrinds because they can't get a decent weld on account of being hollow. Maybe some Eddy current/Faraday nonsense?
              Despite that, (years ago) I installed a set of regrinds that were based on then unavailable sunbelt race cams on an S52. The vanos had to be shimmed and I think the springs and retainers were swapped out. With a custom tune and turned up to 7200(iirc) it made 292 rwhp on a dynojet.
              Once race later upon inspection, the cam lobes were starting to wipe. womp womp.
              • pazi88
                • Sep 2015
                • 584
                Welding the cam lobes is no go. It messes up the hardening of the cam. Regular regrind is fine if not too much material is taken off the base circle.
                • gazellebeigem3
                  • Jun 2005
                  • 3712
                  ah my bad. I had/have welding and regrinding linked in my mind for whatever reason. Probably in part due to that project; those cams were quite aggressive.
