How much did you spend on your swap?
  • permit
    • Mar 2005
    • 3363
    M50B25; total: $2000ish
    $1000: donor 525i
    $400: JBR flywheel
    $XXX: misc stuff
    $500: full exhaust
    M52B28; total: $6855
    $1500: motor, driveshaft, three wiring harnesses, OBD-I manifold, etc.
    $200: DME
    $250: S52 cams
    $400: AA chip
    $300: misc
    $300: labor for cam install
    $300: radiator
    $100: another piggyback from AA
    $400: headers/labor
    $250: Turner S50 chip
    $200: second DME
    $900: IE catback/labor (Y-pipe)
    $100: cone filter/heat shield
    $155: Euro HFM
    $300: second oilpan/labor
    $1200: new vanos
    • Jand3rson
      • 37587
      I'm saving the money and preparing to do this swap over this coming winter, so it looks like about $2k is what I'll need to get the project off the ground. It's going to just be a stock M50, I'll worry about buidling it up later. I can't wait to get this going.
      • Beej '86 325es
        • 2639
        Originally posted by FredK
        Beej, what's a Turner kit? Cam kit?
        Yeah, Schricks, injectors, and chip to go with the Euro HFM.
        -Brandon
        '86 325es S50
        '12 VW GTI Autobahn DSG
        '03 540i M-Sport (sold)
        '08 Jeep SRT-8 (sold)
        For sale:
        S50 TMS chip for Schricks
        • Stu Mc
          • 4083
          Originally posted by jrez
          too much, and still spending!! Schrick cams just ordered...
          Nice car, couple questions for ya.
          Were you able to use the E30 booster since the OBD-2 intake manifold is not as wide?
          Are you swapping to an OBD-1 manifold before putting in the Schricks?
          • Brew
            • 3060
            S50B30
            Paid $3k for the complete motor.
            Probably another $2k in motor-swap related parts.
            Only paid $800 for the car though, so for about $7.5k including suspension and body mods I've got a pretty sweet car, I think.
            '91 318is
            • DanGillan
              • Mar 2004
              • 4061
              about 2k including TONS of maintenance stuff that wasnt necessary. mad hookups though.
              Dan
              • The Fast One!
                • Jul 2005
                • 856
                almost got everything for mine,
                at about 2000 I think. prolly about 2200 when I'm done (I"ll repost final sheet when I'[m done)
                Mike Fritz
                • Jand3rson
                  • 37587
                  So about $2k-2500 is the magic number to get it done? Right on.
                  I should be able to get a lot of stuff, probably the motor itself for a decent price.
                  • Brew
                    • 3060
                    I've gotta say, after doing the 24v swap twice, I would recommend against doing an M50 or M50tu as a "mod". Its definitely a good upgrade if you have a blown M20, but not a big enough power increase to justify pulling out a healthy motor.
                    '91 318is
                    • FredK
                      • 14761
                      Here's what I'm in for so far
                      S50 with DME, no harness $2500
                      Harness $100
                      413 EWS Delete, 24#, Euro HFM software $200
                      24 lb injectors ~$180 (not purchased yet)
                      Euro HFM $165
                      Radiator hoses including 4 way $$$ hose $156.36
                      Spark plugs $23.58
                      OE composite impeller water pump $70.90
                      thermostat $14.27
                      thermostat housing and gasket $18.20
                      VC gasket $23.00
                      main accessory belt $12.43
                      2 quarts Redline MTL $15.18
                      2 quarts Redline 75/90W Gear Oil $15.18
                      Mahle oil filter $5.18
                      15x valve cover seals $10.26
                      exhaust gaskets $8.85
                      exhaust flange gaskets $10.20
                      oil pan gasket $21.09
                      exhaust header nuts at head $9.12
                      pilot bearing $7.73
                      E36 chassis plug $21.00
                      E36 throttle cable $24.00
                      e28 m5 mounts $35.00
                      320i trans mounts $35.52
                      E32 735i 25mm MC for modified 320i booster $108.17
                      E36 radiator $143.34
                      E21 320i brake booster w/ modified shaft to 15mm $156.14
                      E34 oil pan, dipstick and pickup tube $268.00
                      OBD II exhaust headers $95.00
                      OBD II exhaust downpipe and catalytic converter $170.00
                      M3 Exhaust $100.00
                      Treehouse eyeball arms $140.00
                      E36 328i/M3 driveshaft $105.00
                      E36 328/M3 transmission $472.50
                      flywheel and pressure plate $50.00
                      E30 3.25 LSD $260.00
                      PS reservoir $14.67
                      new S50 clutch friction disc, throwout bearing $161.93
                      clutch slave cylinder $45.66
                      OBD-I O2 sensor $65.30
                      E30 325i/318is center bearing and center bearing support $37.80
                      Power Steering Hose reservoir To Steering Rack $17.43
                      Mintex Front Brake Pads $34.64
                      Mintex Rear Brake Pads $26.57
                      Front Brake Hose (2) $14.60
                      Rear Brake Hose inside Hose Between Metal Lines (2) $13.80
                      Rear Brake Hose outer Hose To Caliper (2)$15.38
                      Clutch Pedal Pad $3.26
                      Water Temperature Sender $4.08
                      Subframe mounts (2) $41.08
                      FTE Clutch master cylinder $46.28
                      Clutch master hose connector $1.51
                      Febi front strut mounts (2) $53.52
                      Front strut rubber stops (2) $10.28
                      Front strut boots (2) $3.12
                      Front brake disc set screw (4) $6.16
                      Rear shock mounts (Meyle HD) (2) $18.80
                      Fuel filter $13.14
                      Rear shock mount gaskets $0.80
                      Evo brake rotors for M3 $120.99
                      M3 rear brake rotors $78.99
                      Hose clamp, 12-15mm (6) $7.50
                      Hose clamp, 15-19mm (6) $7.50
                      Hose clamp, 28-33mm (6) $4.50
                      M10 locknut for driveshaft (4) $2.00
                      Clutch hose, slave cylinder to master cylinder, soft line $29.25
                      Rear support mount for shifter arm $20.00
                      Rear shock mount nuts (4) $2.00
                      Misc parts, including bell housing bolts, bell housing gasket, locating dowel pins, shift console, shift bushings, bitch clip, guibo locknuts, 6 copper lock nuts for headers, 24 hardened valve retainers and 48 valve collets to replace soft ones on the 7/95 S50 I have, ~$275
                      5 lug swap and wheels ~$1300
                      ~$8100
                      Pedal box for an auto to manual swap $30
                      Manual trans cross brace $20
                      Clutch master cyl
                      Clutch hose and piping
                      • jrez
                        • Oct 2005
                        • 71
                        HI,
                        I used a modified 320i booster, and I am concerned with installing the OBD1 intake(I have one) as it definately looks wider, particularly in the plenum width.
                        I don't have a lot of clearence with the current setup, so I'll wait till I start fitting it, as i do want it installed along with the cams.
                        Any info concerning this appreciated.
                        On another note, I can't say I'd pull an healthy M20 out either just to install an M50, but maybe more so with an M52, but Im kinda biased I guess:D . A friend has a healthy 89 325i, and although it is no contest
                        between our cars in a drag race, he's not that far off in the twisty stuff.
                        I've never done a turbo install in a 325i, but that mod would put you up, and more likely beyond, the m50/52 swap.
                        My two cents....
                        At the race track.
                        • permit
                          • Mar 2005
                          • 3363
                          The OBD-I manifold will fit with a 320i booster in there.
                          • The Fast One!
                            • Jul 2005
                            • 856
                            I just put my manifold on last night with the booster in, fits perfect.
                            Mike Fritz
                            • jrez
                              • Oct 2005
                              • 71
                              :D Awesome. Thanks guys!!!
                              John
                              At the race track.
                              • fcsteve
                                • Jan 2008
                                • 227
                                $95 - 95 vanos m50 (115000 miles, perfectly kept)
                                $14 - alternator
                                $16 - ps pump
                                $11 - starter
                                $28 - exhaust manifolds
                                $6 - fuel pump
                                $11 - brake master cylinder (e32 735i)
                                $15 - brake booster (e32 735i)
                                $50 - wiring harness
                                $33 - 3.73 lsd
                                $279 so far
                                i have a track on a red label 413 ecu for $58, e36 motor mount arms for $50
                                my 86 325e was $250, ran great and looked just as good.
                                i gotta track down a getrag 260 and im done.
                                thats how you do a budget build !:D
