Weird No start issue. Cranks but screeching
    I tested the starter off the car, works fine
    Sent from my SAMSUNG-SM-G890A using Tapatalk
      Spins and pulls out
        What starter would u reccomend me go and buy?
          That's a 24v starter. You need m20
          Check Us out on Facebook
          Full Product Line Tuning
            So from a 1989 325i ? So my starter was changed before?
              Issue fixed...
              Utilizing the early model g260 with late model provisions, I rethreaded the carrier bolt without shortening it. It unfortunately fucked with the detents and has left the trans stuck in 5th/reverse. I'll have to tear that one apart...
              So basically the screeching sound was from the trans being in gear. After bleeding the slave, I was able to start her no problem. I eventually picked up another getrag 260 (this time from a late model).
              Everything is a go and fired up/drove first try :)
              91' 318iS - S54/6MT Swapped
              08' E90 M3 6MT - Daily
              Originally posted by IronJoe
              Originally posted by 2mAn
                Must be nice, congrds
