What's a Pilot Bearing
  • The Fast One!
    • Jul 2005
    • 856
    so should I change out my pilot bearing????
    I have the m20 tranny and m50 motor/pilot bearing. it fit in fine so i don't see where there would be a difference....
    Mike Fritz
    • tonytony
      Knee deep in poopie
      • Jan 2004
      • 3498
      i think you should change it cause it's probably worn, and you have everything apart so why not
      • NZM50SWAP
        • Feb 2006
        • 75
        So which pilot bearing do I need???
        92 non vano's 2.5ltr m50 with e30 trans flywheel and clutch.
        • tonytony
          Knee deep in poopie
          • Jan 2004
          • 3498
          the one for the m50, the shaft fits into it just fine
          Edit: I jsut realized using a 260 with the m50, you should switch the pilot bearing to the m20 pilot bearing. The shaft for the 260 is smaller than the ZF. So i ended up using the one that came with the clutch kit.
          • The Fast One!
            • Jul 2005
            • 856
            i'll leave it in, everythin is acctually together (has been for a week)
            I'm ripping it all out again in a month, so I'll get a new one then.
            Mike Fritz
            • e30_kid89
              • Apr 2006
              • 489
              hey guys what about an getrag 240(from a e30 318iS) with the m50 pilot bearing..will it work as well? it would be ashame if it didint cause when i got my motor it came with a brand new one:)
              • Dj Buttchug
                • Jun 2010
                • 7673
                Im bumping this super OG thread because I have a pilot bearing issue
                This OEM part # 11211720310 is suppose to be the pilot bearing for m50 with a G250 trans.
                So that part # cross references to this http://www.autozone.com/autozone/par...h&fromType=oem Which I just went down and bought today.
                The problem is this part doesnt fit. The bearing size is to small the accept the transmission input shaft.
                So if this part # is wrong then what pilot bearing do I need?
                Turbo M42 Build Thread :Here
                Ig:ryno_pzk
                I like the tuna here.
                Originally posted by lambo
                • ForcedFirebird
                  • Feb 2007
                  • 8300
                  They probably gave you the wrong one, or have it listed wrong (why I avoid store front parts stores for BMW parts). The part number matches the large diameter input shaft. The g240, g250 and zf all have the same size bearing ID, and the part number they cross reference shows as the large diameter in realoem:
                  http://realoem.com/bmw/partxref.do?part=11211720310
                  So, their part number is right, part is wrong.
                  john@m20guru.com
                  Links:
                  • Dj Buttchug
                    • Jun 2010
                    • 7673
                    Got it sorted out today. You are correct. figured Id leave this here for others if anyone ever has an issue.
                    The inner diameter of the pilot bushing needed for the larger input shaft is .572 not .473
                    Ig:ryno_pzk
