Gathering parts: anyone want to lend some opinions on trans/diff?
  • fiveightandten
    • Nov 2013
    • 257
    So, I pick up the engine next weekend. This is what i'll have to work with:
    -Swap engine (M52B28, already OBDI swapped, running OBDI ECU with RK tunes custom chip for B28 tune)
    -Car is an '86 325es with Getrag 260 and 2.93LSD
    -I have a 3.73LSD in the garage
    I'm leaning towards just sticking with my 260, and putting the 3.73 in the car when I swap it. However, the person i'm buying the engine from has an E36 Getrag with it for $200 extra. I don't really have any ZF's local to me that i'd trust buying over using my 260, which has 68K on it and I know functions 100%.
    The car isn't a DD, but I don't want it to be too unruly on the highway. Should I:
    1) E30 Getrag 260 >> 3.73
    2) E36 Getrag (extra $200) >> 2.93 (or 3.73)
    And just to confirm, with the 260, i'd just need the modified cross bar, and to bend the shifter? What's the best driveshaft solution for the E36 Getrag?
    -Nick
    1986 325es || 1998 M3 sedan || 2003 330ci
    ~Looking for a left side early tail light, or a set of early tails~
  • bataangpinoy
    • Jul 2008
    • 1636
    Stick with your G260 over the G240.
    I have a 188mm 3.73 R &P I'd be willing to part with for cheap, I swapped it out in favor of a 3.15 R&P. I'm using a ZF320, no overdrive hence the need for a taller R&P.
    My feedback:
    http://www.r3vlimited.com/board/showthread.php?t=186328
    http://e30tech.com/forum/showthread.php?t=74911
    Instagram:
    @gears_n_glory
    @functionmotorsports
    • Ali//325i
      • Jul 2005
      • 270
      If your 260 is in good shape I'd recommend keeping it. plenty of vendors sell the necessary pieces to make sure your 260 sits correctly. Also a 260 + the 3.73 is pretty civilized on the highway all things considered. I'll be sending my diff out to be rebuilt as a 3.46 with my ZF, but that just pushes the build price even higher. I say reuse as much as you can and focus on cleaning up the motor with all new gaskets and maintenance items.
      Engine and tranny mounts with correct transmission brace for your 260
      Condor Speed Shop's Tranny Combo includes our popular 24V swap mounts, a pair of UHMW or polyurethane transmission mounts, and and our aluminum transmission brace!
      You'll need a rotated DSSR to make the shifter sit exactly where it did originally. UUC makes one: https://www.turnermotorsport.com/p-3...rsion/?pdk=AQE there are a few other vendors who make one as well as some forum members.
      The best part of using your 260 is that you don't need a new driveshaft or guibo adapter.
      I bought a Guibo adapter from Revshift to match my m52 and ZF combo to my stock 325i driveshaft.
      • Northern
        I like cupcakes & sh!tboxes
        • 5258
        IMO: ZF320>G260>G250>G240.
        I've seen a couple of bad G250s that sound like marbles or are otherwise trash, and G240's are weak.
        Originally posted by priapism
        Originally posted by shameson
        • agent
          Vice Grand Pubaa
          • 7960
          This. You could even put ZF310 in front of the G260.
          Originally posted by kronus
          • Northern
            • 5258
            ZF320/310 are more or less the same thing, I don't even bother differentiating
            • zakatak47
              • Feb 2011
              • 100
              if you decide to go with the 3.73 and need to sell the 2.93s I may be interested. pm me if so
