c101 and x20 wire diagram (e30 M50 adapter)
  • 328ijunkie
    • May 2007
    • 3961
    #166
    To be honest i havent the slightest idea. Just by looking at that first (of 3) page the ECU connector it looks like a number of things were cross wired. The ECU may be fried, various sensors may be fried, only some digging will tell.
    for instance:
    I am getting spark (even the when the key is in and the ignition is in the on position is still giving me constant spark?? Is this normal?)
    This is bad.
    Again not trying to be a jerk and no problems for wanting a second opinion.
    Check Us out on Facebook
    Full Product Line Tuning
    • M3Fresh
      • Sep 2011
      • 32
      #167
      for instance:
      This is bad.
      David
      In no way are you coming off as a jerk. I understand what you are doing. I was told that it can be done and figured it could also. I apperantly have not done enough research on the subject.
      I will pull the OBD2 harness and try the OBD1 and see what comes from it!
      • 328ijunkie
        • May 2007
        • 3961
        #168
        Do you have OBD1 or OBD2 sensors on the engine? If you have OBD2 ones on there youll need to switch to OBD1 ones....
        • M3Fresh
          • Sep 2011
          • 32
          #169
          I left all the OBD2 sensors on the motor. I plan to swap out the sensors to OBD1.
          its just a Crank, cam, vanos sensor so it shouldnt be too bad. The friends shop that my car is at while doing the work has about 5-10 e36's that I can use as parts on top of countless parts for the swap i guess.
          Ill mess with it tomorrow and report back.
          Just for reference, is this correct pin out for the OBD1 E36 (x20) diagram?
          The E36 side?
          • mtlbloodshot
            • Jul 2011
            • 761
            #170
            The E36 side?
            Interested in finding out the answer to this also
            MY BUILD THREAD
            http://www.r3vlimited.com/board/showthread.php?t=235231
            INSTAGRAM : @luchcolaneri
            • 328ijunkie
              • May 2007
              • 3961
              #171
              ^No.
              And that wont be close to correct for a square c101 car.
              • spyde25
                • 157
                #172
                I am looking for a sanity check before i let the smoke out of the wires. Could someone give my table a once over? i started from a template then went thru the ETMs page by page.
                I am lost as to what action i have with the C103 3 wires everyone talks about as well as if i should do the VSS X20 pin 14 splice.
                1992 318ic M50 out of a 90 e34
                [/url]
                my 88 325i sedan
                • erb326
                  • Jul 2009
                  • 55
                  #173
                  i find no pin out of any e30 missing the same pins i am:
                  im missing 3, 8, 9, 12, 14, 15, 17, 19, 20
                  • Tomas328
                    • Oct 2015
                    • 1
                    #174
                    I am confused as could be, I am working on a 87 E30 putting a S50 in it have both harnesses, and getting a adapter,( had one it was garbage ) no AC so where do I find the wiring diagram, so I can get this thing running, I am ready to jump out a window thank you
