M52 rear main help
  • Ericdkollat
    • Jul 2016
    • 6
    M52 rear main help
    I just changed the rear main seal on my m52. Everything seems to be good with no leaking. Then when I attach the transmission it starts leaking like crazy. So I pulled the transmission back out and no more leak. Last night I put the transmission back in for the second time and its leaking like crazy as soon as i tighten down the tranny bolts. What could this be?
  • TobyB
    • 5287
    shot thrust bearings allowing the crank to slide forward too far?
    Haven't heard of this one before...
    t
    • Ericdkollat
      • Jul 2016
      • 6
      I will be pulling the transmission back out again tonight. I will check to see if there is any play in the crank.
      It only leaks when I tighten the bell housing bolts. Loosen them up and the leak stops.
      • Ericdkollat
        • Jul 2016
        • 6
        No play in the crank. I dont know what to do next. Change the seal again?
        • f4tj0n
          • May 2013
          • 411
          Are you sure its the rear main? Sounds like you could be pulling the PAN off the block some how if its due to tightening the bellhousing bolts.
          • Ericdkollat
            • Jul 2016
            • 6
            The oil pan bolts are torqued to spec so I wouldn't imagine thats the issue but i will double check them. Im getting ready to start on it soon. I replaced the rear main and housing gasket again last night just to be 100 percent sure.
