Oil Cooler, Where? w/ A/C, Aux Fan?
  • b-rad
    • Nov 2015
    • 232
    Facts, 1987 325is / Swapped S50. A/C working. Want to install oil cooler(Setrab 9 Series Cooler 20-Row Engine Oil Cooler, have this already) I have a fan clutch ran off the motor. There is an Aux fan in front of the compressor. Do I: Kill the clutch fan and place dual or single elec fan inside, so I can kill the aux fan? Or could I mount dual fan's in front of the compressor, replacing the aux fan and place the oil cooler to the drivers side. Thank you community!!
    What's the spec on the aux fan?
    1987 BMW 325is,(M3 S50 Swapped)-Current
    2010 FJ Cruiser, aka E30 Support Vehicle-(Daily)
    2008 Scion xB Lowered
    2001 BMW 325i
    1995 BMW 318ti
    1966 Ford Mustang Coupe
    1965 Ford Mustang Coupe
    My Thread
  • b-rad
    • Nov 2015
    • 232
    2001 BMW 325i
    1995 BMW 318ti
    My Thread
    • dude8383
      • Jan 2005
      • 10387
      If you have a/c I wouldn't remove that AUX fan.
      The mechanical fan isn't going to be enough in high heat situations... You can utilize the factory oil cooler. Its pretty sufficient. On hot day's my temp's are around 185/190.
      • b-rad
        • Nov 2015
        • 232
        so might be better to dump the washer container? and place cooler near there or behind air dam under the bumper. I think I might have cut away some sheet metal.
        2001 BMW 325i
        1995 BMW 318ti
        My Thread
        • b-rad
          • Nov 2015
          • 232
          Factory Oil Cooler
          There is no Factory Oil Cooler.
          I bought a Euro Oil Housing, ready for install.
          Just trying to get a real plan.
          2001 BMW 325i
          1995 BMW 318ti
          My Thread
          • dude8383
            • Jan 2005
            • 10387
            The factory E30 oil cooler works just fine.
            Get yourself the S54 oil filter housing plus the necessary plumbing to run the lines and fittings for the feed and return. I didn't drive my E30 to the shop today but I'll try to snap a few pics of the setup I have so you can see for yourself :up:
            • b-rad
              • Nov 2015
              • 232
              Oil Cooler
              I have the Euro housing, lines, oil cooler. I have 3 gauges will be hooking up that the same time. The bimmerworld sensor split for the temp and pressure.
              I turned on the AC last night and took a look at the aux fan... dam that thing is noisy. I still think my small dual fan idea would work. I have Euro Bumpers and I may have to resort to cutting the Zender lower valance, and attempt to make it look cool. I have the plan in my head, just not 100% seeing the oil cooler mounted.
              2001 BMW 325i
              1995 BMW 318ti
              My Thread
              • 2mAn
                Señior Mod
                • 21017
                With the way the Zender valence is designed you could cut horizontal slits in it and it would look fairly normal. Other option is to sell yours and get like a mtech1 front for it
                Simon
                Current Cars:
                -1966 Blue Boat
                -1969 Red VW
                -1986 White BMW
                -2006 Green Thing
                Make R3V Great Again -2020
                • R3Z3N
                  • Jan 2011
                  • 3056
                  Here is what I temporarily did with the stock E30 cooler.
                  • E30-325iS
                    • Sep 2011
                    • 191
                    This is how not to do it. http://www.r3vlimited.com/board/show...postcount=2995
                    • b-rad
                      • Nov 2015
                      • 232
                      Omg that's what I'm trying to avoid!!!
                      2001 BMW 325i
                      1995 BMW 318ti
                      My Thread
                      • b-rad
                        • Nov 2015
                        • 232
                        (2) 8 Inch fan's with 600 cfm do you think would do the job?
                        LINK
                        Then use ebay radiator and Mishimoto elec fan, killing the clutch fan.
                        Mount oil cooler to the drivers side next to fans.
                        2001 BMW 325i
                        1995 BMW 318ti
                        My Thread
                        • M3PO
                          • May 2012
                          • 537
                          Not sure if this helps or not
                          • b-rad
                            • Nov 2015
                            • 232
                            Kinda, I have ac... Nice looking though
                            2001 BMW 325i
                            1995 BMW 318ti
                            My Thread
                            • dude8383
                              • Jan 2005
                              • 10387
                              R3Z3N is pretty much running what I have on my car as well. That's the neatest setup.
